Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-24-2011, 11:43 PM   #1
dbmx66
why does it keep hesistating? help me!
okay, so.....
i had the truck outside a few times in the past week, trying to tune it up a bit.
its irritating the crap out of me. theres this hesitation.
when i sit there and get on pretty good just from idle, its hesitates for a second then i left off for not even a second and get back on it and it screams like it should.
when i sit there and spool the convertor up to 2500-3000 rpm then let off the brake and smash the gas it just falls on its face. again until i left off and get back on it.
the timing is set.
i have tried almost all the different accelerator pump cams and squirters. and still havent solved it.
the hesitation only got a lil better by changing out acc. pump cams and squirters.
what do i do!
is it too much carb? the engines a 350 bored and stroked to a 383, full forged eagle bottom end. 11.5 or so compression, high flow cnc ported heads with 2.05int and 1.60exh valves. with a .575 hydraulic cam, aluminum rockers, vic jr single plane intake with a holley 750 double pump on it.
please help me.
dbmx66 is offline   Reply With Quote
Old 03-25-2011, 09:03 AM   #2
team39763
Re: why does it keep hesistating? help me!
Mine acted like that when I went racing last November. It turned out to be trash in my carb and I also had water and other crap in my fuel cell.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 03-25-2011, 03:15 PM   #3
dbmx66
mine has a fresh holley carb on it, i milled the choke horn off, i made sure every piece was clean and intact before putting it back together.
Old 03-25-2011, 03:49 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
May I ask what size jets you have in the primary versus the secondary? Also, what is your fuel pressure at the bowls?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-25-2011, 11:08 PM   #5
dbmx66
jets are 70s and 72s, pressure is 5-6psi
Old 03-27-2011, 09:43 AM   #6
68longhorn
68longhorn's Avatar
Have you tried different timing settings? I was chasing a simalar issue on a far less radical setup. Swore it was carb related, eventually started different timing settings and that fixed it
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 03-27-2011, 11:12 AM   #7
dbmx66
well the timing was set where we wanted it, i have and msd pro billet distributor in it, it came with different springs and what not, do you think the timing is coming in quick enough?
Old 03-27-2011, 11:56 AM   #8
vin63
vin63's Avatar
Is the 5-6 psi at idle? What type of regulator system do you use? Since it doesn't require a bunch of changes, I would try going down jet sizes on the primaries first to see if there is any change by increasing the spread between the primary and secondary jet sizes.
Old 03-27-2011, 12:14 PM   #9
dbmx66
its 5-6 psi at idle, its a barry grant pump into a barry grant regulator, should i decrease the jets in the front? or increase the ones in the back?
Old 03-27-2011, 07:04 PM   #10
fryco
fryco's Avatar
Did it back fire at all at start-up (ever)? My will knock a power valve out if you look at wrong... Or possible wrong power valve for manifold vacuum. just a idea...
fryco is offline   Reply With Quote
Old 03-27-2011, 11:05 PM   #11
dbmx66
i doesnt back fire at start up, but if i really get on it, it spits out the carb a lil, i thought i might have been hanging a valve hence the spitting out the crab, i checked all my valves and they were all fine. so i have no clue
Old 03-27-2011, 11:40 PM   #12
cableguy0
Where is your timing set at?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-28-2011, 01:06 AM   #13
1970C10truck
1970C10truck's Avatar
I'm also curious to hear your timing specs. Did you actually verify tdc with your balancer and timing mark? Or check the balancer hasn't slipped?
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 03-28-2011, 11:09 AM   #14
vin63
vin63's Avatar
Do you have a fuel pressure gauge at the carb? I'd be curious to see what the pressure drops to initially when you even snap it up to 2500 rpm...I've had to rebuild a few BG regulators in my time. The spread increase in jets would be just to see if there is any change in throttle response. Just trying to diagnose what is causing the delay.
Old 03-28-2011, 11:36 AM   #15
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: why does it keep hesistating? help me!
http://www.ehow.com/facts_5161686_ca...elerating.html
http://www.holley.com/TechService/FAQ.asp
Sent by Enhanced Email from my Verizon Wireless HTC Thunderbolt 4GLTE smartphone.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-28-2011, 12:07 PM   #16
68longhorn
68longhorn's Avatar
I only changed base timing. at 8* it had a hesitation, at 10* my issue went away. What is your timing set at?
Old 03-28-2011, 01:35 PM   #17
1970C10truck
I run my timing at 12* initial 36* total and because I mostly drive on the street I have my vacuum advance hooked up. Vacuum advance is on full manifold and limited to 6*.
Your 8* sounds a little low in my opinion for the motor you listed.
Old 03-28-2011, 03:18 PM   #18
dbmx66
its set a 34 degrees at 2500 rpm
Old 03-28-2011, 03:19 PM   #19
dbmx66
tdc is at the 0 degree mark on the balancer
Old 03-28-2011, 03:22 PM   #20
dbmx66
i have gauge at the regulator, i already sent a barry grant back cuz it was junk, this one works, i just dont know if i should go smaller in front or bigger in the back
Old 03-28-2011, 03:47 PM   #21
shortbed70
shortbed70's Avatar
Sounds like you need to either move to a smaller accelerator pump cam or larger one. If it spits out the top try going smaller first. I also had a 750 holly dp that did that turned out to be a warped base plate sucking air.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-28-2011, 10:57 PM   #22
dbmx66
im gonna give that a try tmrw thanks
Old 03-29-2011, 07:34 PM   #23
fryco
fryco's Avatar
grab a can of ether spray shoot it around the base of the carb (not in it) while the motor is running. If the motor stumbles your sucking outside air around a gasket. shoot it around the intake where it meets the heads also.
check all your vacuum hoses and caps, make sure nothing is cracked. the simple things will make you scratch your head....
Old 03-30-2011, 12:20 AM   #24
shortbed70
shortbed70's Avatar
Well any updates? Did you figure it out?
Troy
Big Red Dog build
Old 03-30-2011, 02:50 PM   #25
Mykk
My vote for ignition timing as well.
I have a vortec headed .040" over 350. 11:1 compression, XR276 roller cam. Mighty Demon 750. I had a bog/hesitation/ stumble off idle too.
Previously I had the distributor set up for 36 degrees max @ 3000rpm with a 24 degree busing, 12 degrees initial and a B26 vacuum advance on ported vacuum.
I just rebuilt/recurved my distributor, used a 21 degree bushing. Set the mechanical to 36 degrees max @ 3000rpm. I also used an adjustable vacuum advance maxed by 8" vacuum and running manifold vacuum. Cleared up all hesitation issues. The engine now fires up, idles and revs faster than it ever has in it's life.
It has 36 mechanical max, 15 cranking. 30 degrees at idle and between 38-51 degrees while low load high vacuum cruising.
Also, if I may suggest. If your SBC is for street use, consider removing the Vic jr in favor of a RPM air-gap. Single planes are steetable, and they drive fine. But I've solved a hesitation in a built SBC by swapping those intakes. myself, I just went from a Super Vic copy single plane to a RPM air-gap copy with a four hole tappered 1" spacer and couldn't be happier with the engine response. Cheers ~Mykk
Mykk is offline   Reply With Quote
