Old 03-25-2011, 06:31 PM   #1
peglegs
peglegs's Avatar
2000 ford explorer rear end info please
im 1st in line for a 2000 ford explorer disc. brake rear end where would i ask the guy to look for the #'s or ? to determine the ratio, elsewhere it was noted that 96-2000 is either 373 or 410 & 60.5 wide. any thoughts on why i shouldnt install this, besides the obvious bracketry, thanks all have a great productive weekend
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 03-25-2011, 06:50 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 2000 ford explorer rear end info please
There should be a small metal tag on one of the cover bolts that has the info on it. It will say the ratio, and will have an 'L' between the numbers if it's a locking diff. Poeple don't always put them back on when thw covers are removed for service though.
ls1nova71 is offline   Reply With Quote
Old 03-27-2011, 01:15 AM   #3
peglegs
peglegs's Avatar
the tag says S612E
3 55 88 9L20 any help appreciated
found it
http://www.fordification.com/tech/rearends_ford13.htm
S612E Explorer 95-01 Mountaineer 99 3.55 8.8 NL - -
Old 03-27-2011, 07:19 AM   #4
JMac11
JMac11's Avatar
Hate to ruin this for ya, but I have had 2 Explorers 2000/2001 as company vehicles. THey are prone to pinion bearing issues and are extremely noisy. The 2000 was finally scrapped, but had the pleasant hum of Super Swampers, the 01 is not as bad. Be sure to check them out closely.
JMac11 is offline   Reply With Quote
Old 03-27-2011, 01:44 PM   #5
peglegs
peglegs's Avatar
ty j mac but im not interested in it as the gear ratio is not what i need. im thinking of going the older 9" route . thanks all
Old 03-27-2011, 01:44 PM   #6
peglegs
peglegs's Avatar
ty j mac but im not interested in it as the gear ratio is not what i need. im thinking of going the older 9" route . thought my answer would help others thanks all
Old 03-27-2011, 02:16 PM   #7
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
they are 31 spline axels, 8.8 ring gear, posi, and same axels and axel bearings as a big bearing 9". very tough rear ends very popular swap for s10s, jeep cherokees, and mustang 5lug conversions. mustangs and rangers are 28 spline and drums. the explorer has very high load rating due to the large axel bearings.
beats the hell out of any 10 bolt and imo just as good if not better than a 12 bolt
heres more info http://www.therangerstation.com/tech_library/Axles.html
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 03-27-2011, 02:18 PM   #8
stich626
8.8 will be fine..
pinon noise,?? it's the same rear set up as the full size and rustang..
stich626 is offline   Reply With Quote
