Old 03-25-2011, 06:52 PM   #1
Hduramax
Hduramax's Avatar
Front End Swap
Can anyone tell me, Is there a lot of fab working swapping the front suspension and brakes from an 87 chevy to a 69 c-10, I mean if I get everthing off the 87 will it bolt/weld into the 69 without a ton of work.
Thanks for any help
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 03-25-2011, 08:47 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front End Swap
Welcome to the board.
You might look here,...
http://67-72chevytrucks.com/vboard/s...68&postcount=4
You have picked a question that gets asked here daily.
There are may build threads that show how easy it is to swap the front to disc brakes.
Keith
Convert to disc brakes.
Old 03-25-2011, 09:17 PM   #3
Hduramax
Hduramax's Avatar
Re: Front End Swap
thanks
2008 HD
2013 Sonic LT
Old 03-26-2011, 10:24 AM   #4
muleys67
Re: Front End Swap
Does this info include 1 ton trucks? I have a 69 C 30 flatbed I would like to upgrade to discs.A wheel up grade also,not wanting the split rims that came on it. Thanks. Muley
muleys67 is offline   Reply With Quote
Old 03-26-2011, 11:59 AM   #5
lolife99
lolife99's Avatar
Re: Front End Swap
Most of the info will work for 1-ton trucks.
I would use the 73-87 1-ton donor truck for your parts.
If you want drop spindles,... they will also have to be for a 73-87.
(the aftermarket doesn't make a "direct bolt-on" spindle for the 67-70 1-ton trucks, like they do for the 1/2 ton trucks.)
Keith
Old 05-21-2011, 08:30 PM   #6
muleys67
Re: Front End Swap
lolife99,will the 73-87 parts swap to my 69 front end or am I needing the complete front suspension? I know about 1/2 ton swaps,Ive just gotten the c30.Thanks for any advice. Muley
