Old 03-21-2003, 07:32 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Holley fuel pressure regulator and Edelbrock Carb Question??
Hi,
I have and Edelbrock #1406 carb. and when I relocate my tank I will use a holley electric pump and a pressure regulator from Holley as well. My question is that the pressure regulator has one inlet and 2 outlets but the Edelbrock only has one inlet so what do I do with the other outlet on the regulator? Can I just get a plug for it or what? Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 03-21-2003, 08:30 PM   #2
mikep
Used to have a truck
mikep's Avatar
Take my advice and dont use the holley, The incessent drone of those damned things will drive you crazy. Spend the extra $50 and pick up one of the Mallory gerotor design pumps. I know some people swear by the Holley but those people have never tried the Mallory. Once you run one you'll never run anything but ! Theyre QUIET !!! and the fuel pressure is a lot more consistent than the holleys and they dont have the problem with shaft seals that holley is know for. Compare the two and the holley even looks like a cheap piece of crap compared to the Mallory gerotor pump.
No truck :-(
mikep is offline   Reply With Quote
Old 03-21-2003, 08:50 PM   #3
1-PU70
1-PU70's Avatar
Just plug the 2nd outlet. Thats what I did with my 1406 and a Holley Reg.Dont use a Holley Pump, to noisey.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 03-21-2003, 11:02 PM   #4
bigjimzlll
bigjimzlll's Avatar
Im using a holley blue pump...I used the second outlet on the regulator for my nitrous fuel feed....Too noisy??? lol..I cant hear it..ofcourse the 3" flow master 40s and the constant roar of frying tires sorta drowns out any little pump noise
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
