14 bolt SF v 14 FF
What is the strength differences between the 14 bolt SF and the 14 bolt FF ? my 1986 Chevy K20 has a semi floating 14 bolt and was wondering if it as good as a full floater .
Re: 14 bolt SF v 14 FF
Nope. Fine for normal use, but put big tires and go offroad, it go boom!!!!!
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
The biggest difference other than ring gear size is, on a full floater you can take the axle out of the truck without pulling c-clips. They are both pretty bulletproof as far as diffs go.
Are there any easy lockers for the 14 bolt SF ? the truck is only going to have slightly bigger mud tires 265 or 285 probably .
Do your self the favor and get a full float!
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Get one out of an 81-86 c/k20
how do you tell the difference?
14ff has the hub sticking out inside the lug nuts, semi has nothing, like a 1/2 ton axle.
Except directly at the splines, the semi-floater axles are bigger diameter than full floaters. Monstrous 33 splines, they're huge. You rock crawlers may have seen one, but I've never seen one break including some deep into the 9's.
There are a few lockers/posi's available, you can do a quick search. Oh, and they're about 100lbs lighter than the full floater. No need to swap one out until you've proven you have enough power to bust a SF, IMHO. |
Yay for me having a ff then. Also i found out A couple days ago I have a 205 instead or the 203 I thought I had.
Posted via Mobile Device |
