Old 03-21-2003, 08:01 PM   #1
pat
pat's Avatar
Speedometer cable
My truck doesnt have a speedometer cable so I bought one, i think 50 inches. It has a 350 with a 350 automatic. Is this the right length cable? How would I go about putting this in, what firewall hole do I use? Appreciate any help.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 03-21-2003, 08:11 PM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
Use any hole you want as long as you try to keep the cable from sharp bends. That is the important part. AutoMeter has Speedo cableless speedometers. That is what I'm going to be using.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-21-2003, 11:15 PM   #3
Blue Beard
Blue Beard's Avatar
Reumster:
What does the cableless speedomters use in place of the cable, electroics?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-22-2003, 07:34 AM   #4
JimKshortstep4x4
Talking
50" seems short to me. The hole you want is shown on this thread. 1971Stepside did a nice job on labelling the firewall holes in this thread.
http://67-72chevytrucks.com/vboard/s...firewall+holes
Jim
Old 03-22-2003, 02:36 PM   #5
pat
pat's Avatar
Thanks for the help so far. If 50 is too short, does anyone know the correct length?
Old 03-22-2003, 05:13 PM   #6
Reumster
L.E.D. Freak
Reumster's Avatar
The electric speedos are spendy, they use a little box that bolts to the side of the tranny, and two little wires run to the back of the speedo. It's easily calibrated, you can change tire size, gears,etc... and just hit a button and it acurate to 2 mph or so
(406)675-8082
Old 03-22-2003, 08:26 PM   #7
JimKshortstep4x4
Talking
I just measured a cable out of a 71 w/TH350 2 wheel drive and it is 61" long.
LMC lists cables at 63" and 83" which would be used for the 2 wd and 4 wd respectively.
Jim
Old 03-23-2003, 12:55 AM   #8
GMC71k20
where can you get the electronic ones? i plan on switching tires and gears often so it could be usefull
GMC71k20 is offline   Reply With Quote
Old 03-23-2003, 09:18 AM   #9
Blue Beard
Blue Beard's Avatar
I guess if the electronic ones are expensive, and you still have to run wiring to the dash...........along with the within 2 miles idea.............don't see this to be any advantage.
If you think about the price of a new cable with or without a new housing, and how long they will last under normal use.............don't see any advantage for the normal user. Street rods that want a clean look, yes.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 03-23-2003, 12:14 PM   #10
pat
pat's Avatar
Thanks for measuring one for me Jim. Helps a lot, I guess Ill return my short one and get a longer one
Old 03-23-2003, 12:44 PM   #11
Blue Beard
Blue Beard's Avatar
I have bought just the cable, that was universal. Just cut it off and put the fitting on the other end.....doesn't hurt to add a little soldier job.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
