Old 03-26-2011, 08:26 AM   #1
kikkegek
kikkegek's Avatar
How to connect a tach to HEI distributor?
hi guys,
I just tried to install a tach to my HEI distributor.
No the Tach terminal is already connected to a white wire, running somewhere I can trace it to. I dont have a tach in my cluster, so shouldnt the tach connector be open?
Anybody know why the tach connector would already be connected in my car?
kikkegek is offline   Reply With Quote
Old 03-26-2011, 09:24 AM   #2
wyattglock
wyattglock's Avatar
Re: How to connect a tach to HEI distributor?
Do you have a remote start system on the truck? If not, maybe a PO had an aftermarket tach installed and just cut the wire and left it in the dash somewhere.
wyattglock is offline   Reply With Quote
Old 03-26-2011, 10:46 AM   #3
kikkegek
kikkegek's Avatar
nope, no remote start. ans the wire is part of a connector that looks original and is for both connections.
I'll try to trace the wire. But it is all taped up!
anybody?
Old 03-26-2011, 11:17 AM   #4
S10Fan
Old Heap Driver
I would disconnect the existing wire and hook up the tach. See if the truck will start and drive it around the block. I'm not familiar with the white wire you're speaking of. Another option would be to connect the existing wire and your new tach wire together.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-26-2011, 11:19 AM   #5
texasfunk
texasfunk's Avatar
I agree. I don't see the white wire being very important especially coming from the tach output.
texasfunk is offline   Reply With Quote
Old 03-26-2011, 02:15 PM   #6
kikkegek
kikkegek's Avatar
OK! thanks for the advise.
I checked the Chilton manual today and it shows the white wire in the electrical diagram from my 86 mode. going from the distributor to the tach.
could it be that they already ran a wire, but didnt connect a tach?
so this tach connector has no other function than to connect to a tach?
Old 03-26-2011, 08:35 PM   #7
ray_mcavoy
Hi kikkegek,
What type of carburetor is on your truck?
The reason I ask is because GM used some carbs with a computer-controlled mixture solenoid setup in the 80's. Mostly found on cars but I've heard some trucks got them too (California emissions mostly I think).
Anyway, many of those computer-controlled carburetor setups have a wire connected to the HEI tach terminal to send a tach reference signal to the computer. If that's the case, you'll need to keep that wire hooked up, but I don't see any problem tapping into it to hook up your new tach.
ray_mcavoy is offline   Reply With Quote
Old 03-27-2011, 07:04 AM   #8
kikkegek
kikkegek's Avatar
hi there. I checked and the white wire is not connected to the carb. But I cant seem to find where it goes...I only see it drop down behind the engine to the passenger side and dissapear into a hose (cover) for several cables. Cant seem to trace it where it goes to.
I'll just tap into it and see if my tach works...I'll be back!
and YES, my engine had lots of california eco-stuff on it we all took of. since there is no need for it in Europe. The car was imported from california last summer
Old 03-27-2011, 12:00 PM   #9
kikkegek
kikkegek's Avatar
tested it just now. connected 12V and ground to the battery and the S (rpm signal) to the TACH signal from the HEI. But I get no rpms displayed.
help?
Old 03-28-2011, 04:34 AM   #10
kikkegek
kikkegek's Avatar
does anybody have the wiring diagram for the ECO part of the engine? My wiring diagrams from Haynes and Chilton only say the white wire from the TACH connection should run to the tachometer. But doesnt in my case.
There is a vacuum diagram in teh Chilton, but no electronics. please help.
Old 03-28-2011, 01:02 PM   #11
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
How many wires do you have with your tachometer? I believe there is supposed to be a green, red, black, and white...The white should be for the lights...and should be spliced or connected to the lights to where when you turn the headlights on...so does it.....the black should be the ground.....red should be connected to the ignition switch because you want it to turn on when you turn the key on.....and green should be on the negative post on your coil.....which should be on top of your distributor unless you have an external coil...don't take this 100% but I think that's how everything is hooked up
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 03-28-2011, 07:15 PM   #12
ray_mcavoy
Hi kikkegek,
I don't have a diagram for the Calif emissions feedback carb wiring, but I'm pretty sure that white wire off the distributor runs to a control module mounted under the dash (behind the glovebox).
Since you removed all the emissions stuff, I think you can safely unplug that white wire from your HEI and replace it with the wire going to your tach. Try that instead of tapping into that wire as I had mentioned earlier. Although unlikely, there might be something in the control module at the other end of that wire that's keeping the tach from getting a good signal.
Old 03-28-2011, 08:26 PM   #13
502ss
502ss's Avatar
Looking in the Haynes 1967-85 workshop manual. They show the white wire going to:
81-85 years
6 cyl - A.I.R diverter module
8 cyl - speed switch relay
The 77 up years don't have a white wire but instead a brown and that wire is shown to go to the tach clusters
I would disconnect the existing white wire and connect your tach lead there!
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 03-29-2011, 07:18 AM   #14
kikkegek
kikkegek's Avatar
81-85 years
he thanks man!
what is the speed switch relay for? what does it control? or check?
Old 03-29-2011, 12:39 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
kikkegek found it page 12-12 @ the back
i'll post it in a bit...looking for cam
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-29-2011, 12:49 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
posted
John
Old 03-29-2011, 01:00 PM   #17
kikkegek
kikkegek's Avatar
thanks man!
i did it. tapped into the white wire and the tach is working.
as soon as I got it built into the dash I'll post esome pics.
its a relly nice little tach that will fit realy nice!
Old 03-29-2011, 03:58 PM   #18
502ss
502ss's Avatar
thanks man!
I just finished adding a tach in where my clock was. I think it came our really good!
Old 03-29-2011, 04:25 PM   #19
kikkegek
kikkegek's Avatar
he man! i am gonna do exactly the same. my tach is a small one like yours too! looks good man!
only mine is yellow lit, and I cant seem to be able to open the thing!
Old 03-29-2011, 04:34 PM   #20
502ss
502ss's Avatar
That's strange. So there is no socket on the back for a bulb?
Who is the manufacturer of the gauge?
Old 03-29-2011, 08:29 PM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
weird that means you can't replace the bulb?
i had to pry my case away from the edge to take my autometer apart(to fix short)
but the bulb i could get from outside
and i used a trailer hitch plug for ez in out
John
Old 04-01-2011, 02:30 PM   #22
kikkegek
kikkegek's Avatar
how did you mount your tach inside your dash? any pics?
Old 04-01-2011, 08:37 PM   #23
502ss
502ss's Avatar
I just replied to your question over in my build thread
