03-26-2011, 09:42 AM | #1 |
does these headers fit my 66 c30?
hello guys
want to ask if these headers will fit my truck? and for those try it be4,what u think about the quality ? does they work fine? i want be sure its fit be4 i buy thanks
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
03-26-2011, 09:47 AM | #2 |
Re: does these headers fit my 66 c30?
Yes they will, but if they are chrome they will turn blue and rust eventually, you`re better off getting high temp coated hedders as they will retain their appearance longer, price wise sinse shipping is factor for your you`re better off.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-26-2011, 10:08 AM | #3 |
thanks for help
there r many brands but they are cost to much,and shipping for kuwait is killing me. i have other idea,,,i can use same headers but black coated and use this chrome cover..i think it will be nice..but any one have pics of them instaled? just want to see how they look under the hood.. again thanks
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress Last edited by Q.8; 03-26-2011 at 10:09 AM. |
03-27-2011, 04:54 AM | #4 |
any 1?
03-27-2011, 09:25 AM | #5 |
I haven't seen any headers with those kind of covers before.
07-27-2011, 11:12 PM | #6 |
im working now in instaling the v8 sbc..these headers not fit.it touch the engine mounts.
i pay 1500$ for chrome parts,and many of it not fit such as these headers,oil pan ,alternator brackets and maybe other parts still in the boxes. realy i lose money and time.and will stop to buy other parts and spend more money. now i know what pain in the ass mean.!!
07-27-2011, 11:51 PM | #7 |
60-66 Nut
Sorry to hear of your issues. I somehow missed this thread before. I would have told you no they will not fit. Can you cut the motor mount for clearance?
07-28-2011, 12:09 AM | #8 | |
i found other style i think it will fit,they said in the ad "This is a set of brand new small block Chevy heavy duty truck headers with a chrome finish. They fit 1988-1995 small block Chevy engines using standard exhaust patterns such as 265, 283, 302, 305, 327, 350, 383, 400, etc, and GMC pickups such as 1500, 2500, 3500" what you think captin? or any one instaled them? by the way, have manual trans from 1992 truck
07-28-2011, 12:22 AM | #9 |
60-66 Nut
I do not know for certain, but I doubt those will fit either. The 1988-95 trucks have more room between the engine and the frame. Member Alan's Classic tried a set of 1988-'98 headers on his truck and they did not fit. You might look at his build thread to see what he used that fit. Can you use long tube headers?
07-28-2011, 12:41 PM | #10 |
this is what i used and they fit perfectly.
Hedman 69640 - Hedman Hedders Standard-Duty Uncoated Headers Details Jeep engine swap headers # 1967-91 CHEVROLET,GMC C20, C30, C25/C2500, C35/C3500, C2500, C3500, R20, R30, R2500, R3500, V20, V30, V2500, V3500 PICKUP 283-400ci; 2WD Without smog injection or injection heads. # Will fit with angle plug heads (Chevy aluminum only). # Shortie style hedder. Maximum ground clearance. # Elite replacement gasket #27520. # Not legal for sale or use in California on pollution controlled motor vehicles. # Under chassis exit. # Modification to stock exhaust required to retain catalytic converter. # Not applicable or intended for street or highway use. Legal only for racing vehicles which may never be used upon a highway, check footnotes also. # Not legal for sale or use in California
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
07-28-2011, 01:56 PM | #11 |
It is best to get the flange further away from the exhaust ports. If you run it hard, the flange on block huggers will usually warp and never seal again, regardless of the brand or quality of the block huggers. In fact, aluminum flange seals will melt on them. Aluminum flange seals will not usually melt on full length headers.
I will never run block huggers again. |
07-29-2011, 01:13 AM | #12 |
60-66 Nut
Here are a pair of headers that are designed to fit the '60-'66 trucks. These will work with a manual trans.
http://www.summitracing.com/parts/HED-69260/ Here is a pair of headers that are designed for newer trucks but will also fit the '63-'66 trucks. These will work with a manual trans with slight modification to the clutch bellcrank http://www.summitracing.com/parts/HED-69090/ These two headers are also available in the Elite series as part numbers 69268 and 69890
07-29-2011, 11:26 PM | #13 |
Thanks guys for help.capitan,i think the short one will fit better.
Now im thinking to make custom one,i will cut the base of the headers and lookin for other pipes and weld it to fit my engine mounts. Or i think i will buy the other one attached up.thanks bama36.thanks wildearp
