Burb frame compared to a long bed? Arethey the same?
My next vehivehicle will be this year range suburban. I just found a truck long bed frame cheap are they the same as the Burban if so I might snag it to have painting now and just have it waiting till I get a burb
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
65 suburban vortec 5.3 bagged
Re: Burb frame compared to a long bed? Arethey the same?
check out my thread i also have a long bed frame and a suburban you have to cut 12'' out to make it the right wheel base
Long bed frames and burb frames have the same 127" wheelbase,you would have to add the extra body mount brackets from the burb.Where would you have to cut 12" out?
don't know what you guys are smoking, but suburban frames are 115"w/b and l/bed were 127"w/b the last time that I checked. body mounting from "b" pillar back is different and the rear frame is different. 60-66
ron |
Is that on a 60-66 frame,My truck book is saying 67-72 is 127"?
60-66 offered 3 diff wheelbase 115".127"133" one ton panel.67-72 is only 127"
I assumed bguild was talking about "this year range suburban" he was refering to the year truck in his avatar.My bad,mike.
that is just like trying to assume something with your wife or girlfriend. doesn't always work if at all
ron |
Frame is a 64 lwb. I will hold off since they are shorter. Great info thanks guys.
