03-26-2011, 03:43 PM | #1 |
My first C-10 post/project. What do I need to big block it?
So this is my first post asking questions. I have a 1972 C-10 Suburban. I'll be posting in the Sub/Blazer forum soon.
I have experience with 66 Chevelles both small & big blocks. One is a 4 door station wagon w/408 hyd. roller cam, Dart Pro 1 aluminum 215cc heads SB/700R4/12 bolt 3.73 4 wheel disc brake, family cruiser, Edelbrock pro flo 2 partly on car. The other is a 2 door hard top (the wife is too scared to ride in it) 489 stroker hyd. roller cam, aluminum Patriot Freedom 320 cc rectangular port with TH-400 gear vendors OD/UD Ford 9" 3.50(soon 3.90) gear, 1000cfm Pro Systems Holley carb,(F.A.S.T. EFI coming). Both have AC, cruise, ps, disc brakes with hydro-boost both have Alumitech Reproductions BB radiators with dual 11 fans, B-body spindle 12" discs with Hotchkis/Global West upper A arms. I love trucks also. I have a 95 4x4 Cheyenne with Silverado grill, lowered on 20" wheels with a 406 vortec ported head, hyd. roller engine, long tubes, duals into 1 then out 2. With a built to the extreme 4l60e/4l65e 2000 stall since I tow sometimes. The 72 Suburban came from a few miles away its rusty 307/ps/pdb/ 3 on tree, posi rear, with front sway bar as options. has barn doors. I all ready had a few engine but the 454 that is .030 is the only block (besides a 305 Vortec) that checked out ok to build and I had 10:1 pistons on rods with 3/8 ARP wave lock bolts, ported Iron oval port 781s with hyd roller springs on them fresh off my 489. Also have the RPM Air gap Edel intake short water pump, some brackets, 870 & 770 Street Avenger carbs. Also have new BBC Flowtech scratch and dent ceramic headers. Engine is all most there waiting on hyd roller lifters, timing chain with torrington roller bearing built in and a few other things. I have a 96/97 4l80E being built with a TCI trans controller for it. What I don't know is? Do I need specific BB motor mounts, and custom tranny mount. I'll shorten the drive shaft maybe do a 1 piece if I can. I need a BB radiator. Will any other cars/ trucks swap in with a little work? Will my 66 Chevelle BB Ps bracket work in the sub? Want to lower it 3" front 4" rear on either 17" Torq Thrust type wheels or swap to 6 lugs & use 20" rims I took off my 95 4x4 with lower profile tires? I'm afraid the 6 lug 20s will be too big with that drop. Will it? What all do I need to get rid of the 307/3speed and use my 454/4L80E? I plan on towing a little it has a smaller cam that will pull 1800-5200/5500 rpm. So mild stall 400 horse 450++ ft lbs should be great for all most 6000 lbs. Thanks. |
