Old 03-26-2011, 09:55 PM   #1
Vooda
Heater box hole
Just wantin to see what you guys are using to cover the hole left when you remove the heater box. I have a 65 shortbed. Thanks for any ideas.
Vooda is offline   Reply With Quote
Old 03-26-2011, 09:58 PM   #2
geoff.clark
SheetMetalNoob
geoff.clark's Avatar
Re: Heater box hole
I have not done this yet, but plan to do something like this...
http://www.infantimachine.com/products/007.htm
Geoff Clark
Classic Truck NoOb
83 Chevy Custom Deluxe I6 250 lwb (aka) Trash Runner
geoff.clark is offline   Reply With Quote
Old 03-26-2011, 11:18 PM   #3
rbar
rbar's Avatar
Re: Heater box hole
I had mine closed up with sheet metal welded in. I would think if you already have paint that you could make some flat panels up that you could bolt in or make some kind of clips that hold it in. You could make up or buy some nuts for the back side where you don't actually have to bolt through the fire wall, they could overlap it on the inside. Just some thoughts if you have paint problems.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 03-27-2011, 12:53 AM   #4
Captainfab
60-66 Nut
Re: Heater box hole
You can either cut your own cover plates from sheet metal or try and find a factory set of cover plates that were used with the recirculating heater.
Old 03-27-2011, 10:47 AM   #5
Vooda
Re: Heater box hole
Good ideas. I figured welding a piece of metal was the easiest. They sell parts for everything anymore so i wasnt sure if guys were buying some kind of replacement part. It would be nice if you could put a smaller heater box in those things. The one that was factory is HUGE.
Old 03-27-2011, 11:27 AM   #6
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Re: Heater box hole
I just made one from a piece of 18g sheet metal that I had lying around. I got some gasket material from O'Reilly's and drilled 5/16" holes for bolts. Something quick and you can paint to match your firewall.
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 03-27-2011, 11:36 AM   #7
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Heater box hole
Easy to make up a panel and weld it in.. but I have to ask did you remove the heater or put it inside the cab under the dash??
panel wise locate a door, hood, and cut out what you need. I used a hood, to cut out all the panels I made, gas fill hole, stake holes, the 20 plus holes in the doors from countless mirrors being mounted over the years
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-27-2011, 11:51 AM   #8
Vooda
Re: Heater box hole
I removed it. Not really planning on driving it when its cold. If I do, I will just bundle up. I just really like the look of the firewall without it. What do you mean by mounting it under the dash?
Old 03-27-2011, 12:22 PM   #9
jocko
jocko's Avatar
Re: Heater box hole
Here you go! QUICK! Buy this before it's gone! $19.95 "buy it now", i.e. not an auction.
(it's not mine. I just bought a nice set of plates from a member by listing a "want to buy" ad. Something you might consider if you want a stock plate). Personally, I like the look of the factory blockoff plate. But if one becomes hard to find, the ones that folks have made look very good too. (note the below link is only for the square hole - I have not seen the blockoff plate for the oblong hold at the top of the cowl).
http://cgi.ebay.com/ebaymotors/Heate...item4aa9c9b78c
Old 03-27-2011, 12:26 PM   #10
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Re: Heater box hole
Here are the factory plates we just took off an original Heater Delete truck.
LeftCoast32 is offline   Reply With Quote
Old 03-27-2011, 12:32 PM   #11
kieth
kieth's Avatar
Re: Heater box hole
Most of the new airconditioning kits also include a heater that is inside the cab instead of outside like the factory one. only drawback they usuallin cost one the glove box room.....Kieth
kieth is offline   Reply With Quote
Old 03-29-2011, 09:38 AM   #12
awbrown
Re: Heater box hole
under the dash heater is the standard heater , it will only have 2 controls and the outer 2 controls are deleted.. The under the hood heater is the deluxe heater and it is run by 4 controls.. .. I didnt know this til last week when I started working on truck #2 and had to look truck #1 to see how the cables were routed , and the 2 were totally different .. I always thought 2 of my controls were broke of , but they never existed...
awbrown is offline   Reply With Quote
Old 03-29-2011, 10:41 PM   #13
Vooda
Re: Heater box hole
Mine must be the deluxe because I think I have four controls. I would have to look again to make sure.
Old 04-03-2011, 04:09 AM   #14
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Heater box hole
No the deluxe heaters only had 3 controls like the 1967--72 heater only they only have 3 controls.Well I've owned my chevy truck for over 25 years and love the box on the out side easyer to work on and if it leaks it leaks out side not on my carpet or in my cab and i'm not one to try and fight them understand heater blowers My 1967 3 door has the AC heater added by dealer and it looks like a pain in the ass to work on
stsalvage is offline   Reply With Quote
Old 04-03-2011, 10:04 PM   #15
awbrown
Re: Heater box hole
the deluxe has 4 levers , they are labeled fan ,def,heat,air, one knob actually has the ability to shut off the flow of water to the heater core via a thermostsicly controled valve....the recirculating heater only has fan and defrost .. controls for a 67 are totally different.....
Old 04-04-2011, 06:18 PM   #16
Camper Special
Re: Heater box hole
I see from posts that a few are removing their heater boxes. Any in good shape that anyone might want to part with? Mostly the box itself, mine is rusted out.
Camper Special is offline   Reply With Quote
Old 04-04-2011, 07:16 PM   #17
towersddg9
towersddg9's Avatar
Re: Heater box hole
Here is what I did
towersddg9 is offline   Reply With Quote
Old 04-04-2011, 07:22 PM   #18
towersddg9
towersddg9's Avatar
Re: Heater box hole
before pic
