Old 03-26-2011, 09:57 PM   #1
Eddie H.
Eddie H.'s Avatar
Van Tilt Steering Columns for our trucks.
Does anybody know a good source for parts to rebuild these with?
Do they use the same bearings and turn signal switch as the 67-72 tilt columns?
Are the shift collars available? I have a good tilt column that has a cracked collar.
Thanks guys.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 03-26-2011, 10:15 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Van Tilt Steering Columns for our trucks.
Shift collars are not available new or repop. I always buy another complete van tilt. for parts.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 03-26-2011, 10:21 PM   #3
67chevy1series
67chevy1series's Avatar
^^^^that just came from the steering colum MASTER!!!!!!!!!!!!!!!!!!!!!!!!!!! kevin really know his colums and stuff. my van colum isnt fitting very well in my cab at all.....
67chevy1series is offline   Reply With Quote
Old 03-27-2011, 01:49 AM   #4
stich626
what year vans fit?
stich626 is offline   Reply With Quote
Old 03-28-2011, 08:47 AM   #5
bguild
bguild's Avatar
okay I have a couple questions.. I found a van tilt and the guy wants 85 bucks for it.. Here are some pics.. should i buy or hold off? I have a 67 that I am putting a 700r4 so I know I will need to get a new indicator for the 4 sp change..
Sorry to somewhat hijack the thread but it relates to your ques kinda.. Thanks
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 03-28-2011, 09:19 AM   #6
70shortfleet
70shortfleet's Avatar
If you are lucky enough to find one in a junk yard, they are about $45-$75 range. If you don't buy it, give me the guys number, I will buy it!
70shortfleet is offline   Reply With Quote
Old 03-28-2011, 10:02 AM   #7
bguild
bguild's Avatar
Yes i willl be buying it just wanted to get another opinion. By the pics this should work in a truck right? I have seen the how toos on colapsing the intermidiate shaft etc... so I know its not plug in play but this is a true van tilt correct?
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 03-28-2011, 02:22 PM   #8
bguild
bguild's Avatar
I think 73-82 van columns work.. also keep an eye out for mobile home tilts they fit and dont require as much modifications as the vans.
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 03-29-2011, 02:45 PM   #9
Eddie H.
Eddie H.'s Avatar
Does anybody know where to buy parts to rebuild one of these columns?
