Another headlight question
Ok so I may be asking the dumbest question, but whatever happened to the only dumb question is the question in asked? So please be nice to my question...
'85 type dual headlights which run vertical are "4x6" headlights, right? What are the dual headlights on '89-'91 suburban which run horizontal? I kno you an walk into the store an ask for the year, make, and model and they'll give you the bulb you need. I was just wanting to look at all of my alternatives before making any purchase...recession, the economy, etc. So help me out would ya and don't snicker too hard while you're typing in your answer. ![]() Posted via Mobile Device |
Home Built '87
Re: Another headlight question
Not sure offhand but it may say in the LMC catalogue.
I think the sub lights are definitely smaller and more rectangle'd.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Heeelllpppp somebody. Please. Yea the suburban lights are smaller, the door openings measure 4x6, but the actual bulbs are way smaller. When you look for aftermarket/ other applications besides the suburban what measurement do you use?
Hi DREAMER1,i have a 90 gmc jimmy with the same grill and lights as the sub.the lights in question are 150mm.
My truck sounds so cool....cause my muffler fell off!!!! |
BMW & ASE Master Certified
dude I read your post like 3 times and it just doesnt make sense... what do you want to do, get better lights for your 85 or 90 suburban. they are 2 different sizes and are not interchangeable. simple as that. what ever front end you have, get the bulbs for it... ?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
In the Forgotten far North.
![]() Join Date: Jul 2007
For your 85 model the headlight part #'s are H4656 for the Low Beam Halogen and H4651 for the High Beam Halogen. Dimensions are 100X165mm.
For an 89-91 model Suburban,Crew cab or Blazer with the 4 headlight system, The part numbers are H4703 for the Low Beam and H4701 for the High Beam. Dimensions are 92X150mm
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
| Bookmarks |
