03-27-2011, 10:32 AM | #1 |
3/4 VS 1/2 front suspension differences?
Trying to determine what are the different parts between 1/2 and 3/4 ton front end's for a 67 2WD LWB.
Is it just upper and lower ball joint's, spindles and brakes? Or is the complete cross member, tie rod, and different A arm's and shafts? Thanks in advance..
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 03-27-2011 at 10:34 AM. |
03-28-2011, 12:24 AM | #2 | |
67-72 parts collector,…
Re: 3/4 VS 1/2 front suspension differences?
Upper and lower ball joints are different. Lower a-arm is different. (bigger balljoint hole in the a-arm) Spindles are different. Tie rods are different. The later 71-72 and 73-87 trucks share a few more parts since they are disc brake equipped crossmembers.
