lowering a 61 chevy c-10
Does anybody know what I would need to do to lower the front of my 61 c-10? It doesn't have the coil spring front end, I would like about 3 up front and 5 in the rear if possible. I do not want to change front spindel's cause everything up front is in good shape and to be honest my funds a low. thanks
Re: lowering a 61 chevy c-10
You can get 3" easily by loosening the rear adjustment bolts on the torsion bars.
I got 3-4" drop on my old 60 by doing this. **Now..It was on the bumpstops, so I removed them. It also leaves the bolts hanging pretty low. I dealt with it, but others dont want to. heres pics...
Tim Road Hounds |
Got the truck all lowered yesterday, looks killer! Thanks Grumpy for all the info!!!
nice, i will look at it this week, do you know a cheap place to buy drop springs for the back?
The red 60 had a used pair of jeep TJ rear springs bolted in back. I paid 40 bucks at the canfield swapmeet.
Do a search here on jeep springs. Theres alot of info. Early 90s jeep wrangler tj rear coil springs are a direct bolt-in and lower around 4"
Tim Road Hounds |
how does that truck ride? did it require special shocks?
Grandpa in the rustmobile...
only downfall to jeep springs is if you haul anything the truck will bottom out easily, you can make your own relocators let me know if your interested
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Chevy Only Tx
That red c10 is nice bro!
Chevy Only Tx......... |
Dude! You've gotta post pictures? What method did ya use?
