03-21-2003, 11:12 PM | #1 |
Steering Column Help?
My Friend has a 72 blazer that the prior owner WELDED the steering wheel on. as you might expect he is going to change this column. What years and models will exchange? ....................Thanks 71 Big Red.
big red 71 |
03-22-2003, 01:02 AM | #2 |
KEEP ON TRUCKING
67/72 will be a direct bolt in except some early ones had a 1 piece shaft some vans will work but you have to modify them
72 cheyenne 2wd lwb 71 k20 sons bassett va |
03-22-2003, 01:16 AM | #3 |
Shadetree, thanks for the reply,We will start looking. 71 Big Red
big red 71 |
03-22-2003, 08:17 AM | #4 |
1969 Custom 30 wrecker
There may be a difference in the wiring harness plug on some. I put a junk yard column in my '71 and the plug was different. Not sure what the deal was on that??? Anyone know?
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
03-22-2003, 03:04 PM | #5 |
Thanks Bob, we will chesk plugs prior to purchase, thats something I would not have considered. 71 Big Red
big red 71 |
03-22-2003, 08:59 PM | #6 |
Replacement turn signal switches were made with the later connector plug,and then they made up adapters to connect the new style with the old. Adapters are available, so if you find a column that you really like with the newer style plug on it then there is an option for you.
Otherwise changing connectors can be accomplished with a little work. Jim |
