Old 03-27-2011, 05:11 PM   #1
Hazieview
Building Dreams out of Dimes!
Behind Taillight Gas filler drawings... Will it work?
Okay guys I installed my custom fuel cell from Performance online that I payed way to much for () and had sprayed with bedliner. See if you all can understand what I'm getting at here.... I suck at explaining so this may be a waste of everyones time
Here is my tank with the fuel neck pointing towards the rear of the truck.
It comes with mounts welded to it that match to the frame pretty well. (Bolts will be replaced when tank is permanently installed)
Here is the hole behind the tail light that I will fill the gas from.
This fuel filler cap will bolt down inside this whole.
This is the bottom side of the truck where the fuel fill line will enter from the tail light above. The red arrow represents where the hose will enter. The blue line represents the 5" space that my 90 will have to be able to turn in order for the fuel to flow properly.
This shows the path the fuel line will travel until it gets to my fuel cell...
The green line now represents the fuel flow path into the fuel cell.
Here is an outer view to give another point of view.
Well guys what do you think? Will it work? Should i go with 2 mandrel bent stainles 1.5" 90s to make my bends or should I just go with one single 4ft/1.5" fuel filler hose and bend it accordingly?
Thanks for your input!
Hazieview is offline   Reply With Quote
Old 03-27-2011, 06:24 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Behind Taillight Gas filler drawings... Will it work?
Use the mandrel bends but remember to leave at least a 3-5* downward angle from the taillight bend to the tank to keep the fuel from pooling up in the hose and making it difficult to fill up.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-27-2011, 09:51 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with BLE 'BURBAN, Need more angle than shown, I'm interested in seeing what you do with the tail light....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-27-2011, 09:57 PM   #4
Pop's C-10
Pop's C-10's Avatar
502ss is doing one on his dulley
Start @post#111
http://67-72chevytrucks.com/vboard/s...=435540&page=5
Pop's C-10 is offline   Reply With Quote
Old 03-28-2011, 12:24 AM   #5
Hazieview
Maybe instead of running the fuel filler hose straight over I can angle it from the filler neck to the fuel cell. Shouldn't be that hard I dont think.
Just wondering if I'm on the right path with what I'm doing...
Old 03-30-2011, 06:15 PM   #6
Pop's C-10
Pop's C-10's Avatar
Angling it souldn't be a problem..you may have to open that hole under tha tall light & trim tha lip down in front of tha filler going in tha tank..
Old 03-31-2011, 09:21 AM   #7
Low87
been here longer than Liz
Low87's Avatar
Awesome, thanks for the pictures. I'll be doing the same thing soon except my filler neck comes out of the top of the tank (Burb tank) so I think I'll have some space issues under the bed.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-31-2011, 12:42 PM   #8
Hazieview
To be honest I should have used a suburban tank. I payed way too much for my aluminum fuel cell. Especially since it was modified. Oh well. I hope my idea works.
Old 03-31-2011, 01:01 PM   #9
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Yeah, you do need more of an angle...possibly make the angle higher up when it goes through that bottom hole and then just have a slow angle down the whole way....I really like the idea's people come up with for stuff like this.....creative thinking is cool
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 03-31-2011, 03:50 PM   #10
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
nice tank. The tail idea is very cool.
West Texas Z is offline   Reply With Quote
Old 03-31-2011, 08:20 PM   #11
Blue Chevy 1987
Blue Chevy 1987's Avatar
i love it! im going to put a blazer gas tank in mine an been wondering how i was going to do that!
Blue Chevy 1987 is offline   Reply With Quote
Old 03-31-2011, 08:30 PM   #12
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Not runnin a rear crossmember?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-31-2011, 09:31 PM   #13
SeanPaintsFlames
SeanPaintsFlames's Avatar
Just don't ever get rear-ended!
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-31-2011, 10:32 PM   #14
Squareforceone
Squareforceone's Avatar
lol i wish i could find the site but about a month ago i found a pic on google of someone that did that to a square so its possible
Squareforceone is offline   Reply With Quote
Old 03-31-2011, 11:55 PM   #15
Altec
Getcha Pull
Altec's Avatar
Well, between the hitch, and a bumper I think he is fine.
Thought I'd post this.
http://67-72chevytrucks.com/vboard/s...96#post4450196
Anything past level will work, you'll just have to fill it slowly, and make sure you have a proper vent setup.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-02-2011, 11:28 AM   #16
Hazieview
Not installed yet...
They'll know it before I do!
I agree with both statements. I was told I really didn't even have to have the rear crossmember since I have the hitch but I'm going to install it anyway.
About the vent setup... I payed like 60 BUCK$ just so I could get a fill cap with the vent. I would absolutley not recommend doing this setup without a vented fill cap.
Thanks for the replies and feedback guys. Keep them coming!
I'm suprised no one has mentioned that there may be a possibillity of a fuel being spilled or splashed behind the tail light. Then the possibility of a short in the tail light....... Might make for an impressive boom though!
Old 04-09-2011, 06:27 AM   #17
fast75
Go Hard or Go Home!
fast75's Avatar
wouldn't there be an issue with a gas filler being located so close to an electrical source? good idea i agree but could also give new meaning to the term HOTROD.
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 04-09-2011, 07:39 AM   #18
Hazieview
Originally Posted by fast75 View Post
wouldn't there be an issue with a gas filler being located so close to an electrical source? good idea i agree but could also give to meaning to the term HOTROD.
Read the last sentence from the post right before yours. I mentioned that...
My thoughts..... I'd be more worried about the teenage chick on her cell phone rear endining me than an electrical short.
Good thing about building your own truck is you can build it as safe as you want.
Old 04-09-2011, 07:59 AM   #19
Pop's C-10
Pop's C-10's Avatar
Chevy did it in 55 & i've never heard of one going boom cause of it,,
Old 04-10-2011, 04:11 AM   #20
fast75
Go Hard or Go Home!
fast75's Avatar
i knew that one of the tri 5's had done it, just wasnt sure which one. as i said: a good idea but that would be a concern for me.
Old 04-10-2011, 06:35 AM   #21
westie 666
westie 666's Avatar
the chevy with the filler in the tail light is 1956, my brother has one.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 04-10-2011, 09:21 AM   #22
502ss
502ss's Avatar
Start @post#111
As pop's said, I just did this on my dually. I chose to use a burb tank which has a neck that exists on the top of the tank and points towards the side of the truck. You will definitely need to use mandrel bent pipe as you will have trouble finding a "gas rated" fuel hose that can bend the tight radius you will need. Forget about exhaust shops as most of them won't be able to bend the radius you need. I ended up going to a guy that builds custom headers and he was able to bend me a piece. I will snap some finished photos of mine today and post them up.
I like your gas filler choice but I am not sure it will work. If your plan is to mount the flange to the hole in the light pocket, once you weld or hose clamp the mandrel bent tube to the bottom of it I think you will find your horizontal run is lower then the tank neck. Again I will snap a phot so you can get an idea how tight my bend is and how close the horizontal run is to the floor.
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 04-10-2011, 09:49 AM   #23
Hazieview
Installation complete! Just needs a little tweaking. I did end up not booting the filler to the hose. I'll post pictures later do yall can see why.
The way I cut rverythin made the bends flow naturally and I did it with that fuel filler hose I posted earlier.
Old 04-10-2011, 10:05 AM   #24
lakeroadster
Does the tank have a seperate vent line?
Have you filled the tank at a gas station yet? Does it require that you fill it slowly to keep it from puking back out?
lakeroadster is offline   Reply With Quote
Old 04-10-2011, 12:10 PM   #25
Hazieview
Since none of my post made since I figured I'd retype it. I'm trying the new technology thing where you type stuff from your phone. As you can see I am not good at it at all.
What I ment to say was
I did not end up bolting the filler to the hole where the wires came through at the bottom. The way I cut everything out made the bends flow a little more natural with the four foot fuel filler hose I bought from summit.
The fuel cell does have a vent at the top of it. Yes.
I have not had time to fill the truck up yet. I just got it installed yesterday. Plus I dont even have my fuel lines hooked up or my radiator ordered
I'll post pictures soon but it will be a while before I test it. I'm going to try to do a video when filling to prove if this was a complete waste of money or not.
Bare with me guys! thanks for all the feedback!
