Old 03-27-2011, 08:15 PM   #1
jcblue
jcblue's Avatar
need opinions on a carb for my truck
what have yall had the best luck with.. I just want a good driver.. start and go, no adjusting every season and so forth.. I have a stock 350 with a mid cam.. and a performer intake.. thanks
jcblue is offline   Reply With Quote
Old 03-27-2011, 08:48 PM   #2
hugger6933
Re: need opinions on a carb for my truck
My thoughts are if you want to ride ,EDELBROCK if you want to tinker,HOLLEY. Both are very good and I used many of each with satifactory results but I would recommend the 600 ele. choke EDELBROCK cause you can set it once and drive. You must know the major faults with that carb is that sometimes one a dual pattern intake like the performer you might need a different carb gasket to make sure the base is sealed. Second the needle and seats are touchy and you need a really good filter in front of the carb. Iam sure others will chime in on the age old quandry holley vs. edelbrock/carter vs.qjet. to each his own and all are graet when good junk when not. I no that helps you NONE. So Junk it all and go with a TBI [jokeing] .Jim
hugger6933 is offline   Reply With Quote
Old 03-27-2011, 08:56 PM   #3
bucketObolts
bucketObolts's Avatar
I run a Holley Truck Avenger because they can still function at some pretty steep angles since I'm on bags and will have the motor running with the rear all the way down and front up or vice versa or side to side. Ive also used a street avenger on my old 71 and never had any problems. But I will say I wouldnt mind running an edelbrock either, and I have with no real problems. Im not hung up between the two but I am still young
bucketObolts is offline   Reply With Quote
Old 03-27-2011, 09:12 PM   #4
Boog
laying low
Boog's Avatar
It's always a matter of personal preference. I've been driving and workin on GM vehicles for many years and I prefer a good qjet. It's been good enough for the General all these years so it's good enough for me. I'm comfortable rebuilding them.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-27-2011, 09:23 PM   #5
Robertjust777
i run a holley dp 750 but if you want to just start up and go then id go with what bucketobolts said.
Robertjust777 is offline   Reply With Quote
Old 03-27-2011, 09:31 PM   #6
rico7769
Hybrid67
rico7769's Avatar
Been running a Holley 650 for two years now and have only adjusted a few times to get peak perf. Took only 10 mins or so to do it. Like the previous post, I've found the carb does well on inclines or when I enjoy throwing around a parking lot!!!! Heard good things about edelbrock too, just found a better value from this one.
I'm also running a sb350 with perf intake and hei setup.
Good luck!
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 03-27-2011, 09:36 PM   #7
Robertjust777
ya i like more performance and went with a 750 dp and a proform body but it starts up right away 1 pump but i am running a holley blue electric pump on a 350
Old 03-27-2011, 11:10 PM   #8
mixermike
mixermike's Avatar
i have mild cam and performer rpm intake on my 350 with a 600 edelbrock electric choke.the carb has been on the motor 3 years and no issues at all. i just put a 750 edelbrock on a 396 in my other truck because i was so happy with the 600.
mixermike is offline   Reply With Quote
Old 03-27-2011, 11:33 PM   #9
nastyc10
nastyc10's Avatar
I've been running a 600 edelbrock on my modified 350 for 5 years with zero issues. It starts right up every time and I've never messed with it.
nastyc10 is offline   Reply With Quote
Old 03-27-2011, 11:36 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I've had good luck with my q-jet (rebuilt several years ago) on a Performer 2101. I don't tinker with carbs other than idle adjustment if needed, so it has not been touched and still works well.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-27-2011, 11:39 PM   #11
jcblue
jcblue's Avatar
great.. keep em coming.. i have some price research to do now
Old 03-28-2011, 02:49 AM   #12
Keller
Keller's Avatar
Unless you have a HEAVILY modified engine in a truck that you'll be racing only, a Q-jet is the way to go. Chevy put em on all of their high performance muscle cars for a reason. The smallest 4 barrels will flow plenty when your foot gets heavy and the smaller primaries will give you better gas mileage than a holley or edelbrock. It is still to this day one of the most sophisticated (which is actually a good thing) carbs ever designed/built.
Keller is offline   Reply With Quote
Old 03-28-2011, 02:53 AM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Holley carbs are not as hard to "tune" as everybody thinks. A Holley 1850 (600cfm) would be a good choice. Or one of the Holley "Avenger" series of carbs...
The Q-jets are good carbs... but finding a good rebuildable one (which includes having the throttle shafts rebushed) is getting to be a pain.
Edelbrock carbs suck... but that's just me...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-28-2011, 02:56 AM   #14
wheel
Edelbrock 600cfm!! 2 years, stock 350 no problems!
wheel is offline   Reply With Quote
Old 03-28-2011, 08:38 AM   #15
68Stepbed
68Stepbed's Avatar
I have a 570 Holeey Street Avenger on mine. I've had it for 6 years total with no issues. Been on there 3 years now with the same initial tune.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-28-2011, 10:20 AM   #16
Sinister
Between Trucks...
Sinister's Avatar
I've been very happy running Edelbrock carbs. A Quadrajet in good condition is a nice carb, but the Edelbrocks are very easy to tune. Haven't had the pleasure of messing with any Holleys, so can't comment there.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-28-2011, 10:34 AM   #17
MARKDTN
I would convert to fuel injection. If you must have a carb, then a Holley if you want reliable performance and don't care about mileage. A Qjet if you want to drive it and want mileage. Not just anyone can build a Qjet, I used to have good luck with the rebuilt by Holley Qjets from Auto Zone, but I have heard bad things lately. I had one built by the Carburetor Shop in Ontario CA one time and it was really nice.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-28-2011, 11:44 AM   #18
406 Q-ship
406 Q-ship's Avatar
If you want the closest to Fuel Injection without the hassle.....Q-JET
Carter/Edelbrock is a close second to the Q-jet.
Holley is about going fast with tinkering, Holley is just a semi-controlled fuel leak.
I have built plenty of Holley's and Quardajets, along with working on a few Carters/Edelbrocks. Most of my vehicles have Quardajets and one has a Edelbrock (due to 4500 series style intake or it would have a Jet too) and they all start and run like a late model fuel injected car. All the Holley have been problematic to say the least, pulled everyone off any street driver.
How about looking at Fuel injuection.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 03-28-2011, 01:16 PM   #19
Stricklinator
Stricklinator's Avatar
I am running a Summit 600 CFM with electric choke and it has been great so far-easy to work on and the price is hard to beat:
http://www.summitracing.com/parts/SUM-M08600VS/
Stricklinator is offline   Reply With Quote
