Old 03-27-2011, 08:15 PM   #1
REVS
Door openings
Are the any specs. Or dimensions from the a-pillar to the b-pillar.
I need to do some floor repairs and what to set every thing with braces before i start.
REVS is offline   Reply With Quote
Old 03-27-2011, 08:18 PM   #2
kilomanjaro
kilomanjaro's Avatar
Re: Door openings
I would highly suggest that if you are doing any floor or rocker repairs that you install the hardtop. That should keep your pillars aligned properly while you are welding in new metal.
Hope this helps.
John
63 Buick Wildcat 425
72 Chevy Blazer CST
72 Chevy C10 Cheyenne
00 Ford F-350 Super Duty 7.3L
09 Dodge Challenger SRT-8
10 Ford Expedition Limited
kilomanjaro is offline   Reply With Quote
Old 03-27-2011, 08:23 PM   #3
REVS
Re: Door openings
I will try to bolt the top on first. I have never had a top bolted down. I seem to be missing what ever clips the top to the windsheild frame though.
Old 03-27-2011, 08:35 PM   #4
Bentblazer
Bentblazer's Avatar
Re: Door openings
This might help: but as said bolt top on first
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 04-01-2011, 06:16 AM   #5
vtblazer
vtblazer's Avatar
Re: Door openings
Good reference pic but incorrect dimension's.
The lower door opening measurement is wrong.
vtblazer is offline   Reply With Quote
Old 04-01-2011, 06:42 AM   #6
vtblazer
vtblazer's Avatar
Re: Door openings
Unmolested AZ tub, all original sheet metal.
Measurement land on easy to locate reference points.
Old 04-01-2011, 08:03 AM   #7
Bentblazer
Bentblazer's Avatar
Re: Door openings
Good catch VT, not sure where I found this but I know it was on here somewhere. If I would have looked a little closer I don't think there would be 3in difference between that mea. and the one just above! Might see if I can fix it with your meas.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 04-01-2011, 08:07 AM   #8
vtblazer
vtblazer's Avatar
Re: Door openings
No prob, it's from Rust Parts (I believe) he posted it quite awhile ago.
I think we discussed it deeper into his thread but it never got changed by the looks.
If you can change it, it's definetly a great reference pic.
Old 03-27-2011, 08:37 PM   #9
REVS
Re: Door openings
Thats perfect thanks guys!
