03-27-2011, 08:30 PM | #1 |
1965 Chevy C10, 2005 4.8L/4l60
99-02 cruise control
How do I hook up the cruise on this thing? I have an old stalk but not sure if it will work.
I saw what LS1tech has and that is really confusing.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-27-2011, 09:10 PM | #2 |
BMW & ASE Master Certified
Re: 99-02 cruise control
the factory switch works if the switch is good. just get a schematic of the cruise control system and wire away
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-27-2011, 10:50 PM | #3 |
Clyde,
This doesn't answer your question but here is how I did my stalk. http://67-72chevytrucks.com/vboard/s...d.php?t=324015 I have not been able to get my cruise to work on my 2005 LS2 swap. I think the issue is the following. There seems to be a safety feature that prevents the cruise from engaging if the e-brake is on. Similarly, you can't do a case learn if the e-brake is off. The problem with the E40 computer that I am using is that there is no direct connection to tell the computer the state of the e-brake. Turns out the BCM puts the e-brake status on the low speed serial bus and the ECM reads that. So I am stumped for the moment, but haven't given up. Same problem for the AC request signal, it is put on the serial bus by another controller. I think your case will work OK. Just get a service manual from a vehicle that uses your computer and wire it up that way like 87chevy says. Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
03-28-2011, 09:26 AM | #4 |
factory switch?
03-28-2011, 10:20 AM | #5 |
Cruise Module...
Pin A. Cruise switch on/off Pin B. Cruise switch set/coast Pin C. Cruise switch resume/accel These 3 wire direct to the cruise stalk in the column Pin D. Brake signal, (open with brake applied) Tie onto the wire for the TCC brake switch signal, Should be a purple wire. Pin E. Ground Pin F. Ignition hot Pin G. Stop Lamp signal, (closed with brakes applied) Tie onto the wire that gets hot with the brakes applied at the brake switch, Should be a white wire. Pin J. Cruise engaged signal, Wire direct to Pin 13 of the red connector on the PCM. Pin K. VSS signal, wire direct to Pin 50 of the red connecter on the PCM. What color & how many wires are coming from your existing cruise stalk? |
10-03-2016, 11:45 AM | #6 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-03-2016 at 03:17 PM. |
10-03-2016, 08:02 PM | #7 | |
10-04-2016, 07:51 AM | #8 |
Thanks CB, Kinda figured I was going to be SOL, just thought I would ask. Take care.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-28-2011, 12:23 PM | #9 |
I currently have one off a 72 truck, so I think there is 4, but I am out looking for a stalk that has the eye hole for my stock automatic column, I saw where Rostra has one, would that work better?
Rostra Cruise Control Switch 250-3020 http://www.rostra.com/products/after...by-rostra.html
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 03-28-2011 at 12:25 PM. |
03-28-2011, 10:31 PM | #10 | |
http://cgi.ebay.com/ebaymotors/NOS-8...item4836e3f1eb The later (quick change) style looks like this http://cgi.ebay.com/ebaymotors/NOS-1...item1e5b7bec13 |
03-28-2011, 01:13 PM | #11 |
Clyde, thanks for the Rostra web site. This gives me hope to put cruise control on my 2008 5.3L. Looks like they have plug and play kits for individual years. What a great find!!!
67 5.3L Build |
03-28-2011, 01:37 PM | #12 |
Your very welcome, I may end up going that way also. but I want to attempt to go with the stock ( hopefully cheaper) route for now.
03-28-2011, 06:17 PM | #13 |
Guys,
I tried to use a Rostra switch for the stock cruise but it didn't work like the stock one. So I had to find a junk yard one from a chevy. So if you need a Rostra switch I can fix you up. TR
03-28-2011, 06:24 PM | #14 |
what Chevy did you find one out of TR65?
Did it work on your column?
03-28-2011, 09:10 PM | #15 |
Clyde,
I think most of the later model control stalks work the same for cruise. See the link I posted above. My stalk came from an early 2000's GM. I got it on ebay. The first one didn't function and the seller replaced it with another one. I ground off the wiper / washer tang. TR
03-28-2011, 10:06 PM | #16 |
the switch probally has 4 pins. I am almost sure that they are the same wire color as the diagram posted above too, thats how I wired mine up and it worked fine.
Hey TR, have you tried posting up on hptuners to see if they have a work around for the serial a/c request?.... like in the case of one of my "wants" i was able to turn the tow/haul serial request into a momentary ground signal to operate the mode. Wired the switch to one of the pins on the pcm that said NOT USED, and worked like a champ. clint
03-28-2011, 11:06 PM | #17 | |
That would be really trick if one of the unused pins is setup for the ac request. TR
03-28-2011, 11:57 PM | #18 |
I'm going to assume that by 99-02 you mean DBC? Regardless, they both use the same switch. Look at this thread, you'll see the lever I'm using, and how I modified it. The Rostra and Dakota Digital switches are normally closed switches and you need to use relays to reverse them or find a normally open switch, like a stock GM. http://67-72chevytrucks.com/vboard/s...d.php?t=395093
I have some of these levers if yor interested. |
03-29-2011, 10:41 AM | #19 | |
03-29-2011, 11:13 AM | #20 |
Ls1nova71, PM sent about the switches.
06-20-2011, 12:07 AM | #21 |
I'm a little confused about something. I got under the dash of my 86 suburban to try and map out the cruise control switches and I find one switch that is for the tail lights and one with a vacuum hose on it. do I replace the vacuum switch thing with a senor that tells the cruise that the brakes not pressed? or does the switch for the tail lights do both jobs
06-20-2011, 11:05 AM | #22 | |
06-21-2011, 07:03 AM | #23 | |
I LIKE TRUCKS 1986 GMC Suburban Build Build link 1982 Chevy SWB 2wd Scottsdale, Build Link Sold 1987 Jimmy Build, Project Cheap A$$ Build Link |
