Old 03-27-2011, 09:22 PM   #1
darynblaylock
Question motor swap question
okay,
I have a 1986 gmc with a 305/350turbo trans (long bed)
I want to pull motor and trans out and put it into a shortwide to turn into a show truck (the 305 has sentimental to me)
I have found another truck same year as mine but shortwide that i can get, but i have also found a 92 chevy with a blown up motor.
Both had v8s in them would mounts be a problem?
is the only thing going to be different with them is styling or is there more work to be done with the 92 for my motor to work?
darynblaylock is offline   Reply With Quote
Old 03-27-2011, 10:26 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: motor swap question
No difference between them at all.
And WELCOME.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 03-27-2011, 10:46 PM   #3
3r!c84
Badass
3r!c84's Avatar
i gotta ask. whats up with the 305 man?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-27-2011, 11:14 PM   #4
my4by2
my4by2's Avatar
305's are not "terrible" motors for a daily driver & can even be stroked. Of course they aren't as nice as a mild 350, but if you already have one & it means something to you then build it man! Just be sure to do some work to the heads to increase the flow - that's the big choke point on those engines! And like he stated - all the SBC's have basically identical mounts & accessories.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-28-2011, 12:04 AM   #5
darynblaylock
the 305 is out of my first truck (75 Scottsdale shortwide) i totaled the truck out and thats all i have left from it really
and thanks
Old 04-09-2011, 07:53 AM   #6
fast75
Go Hard or Go Home!
fast75's Avatar
get your heads milled, .202 intake, 160 exhaust valves with a five angle valve job. an edlebrock performer intake and a 650 and sheeeet, you should be good to go, lol.
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 04-09-2011, 10:17 AM   #7
russgt
russgt's Avatar
Are you sure you can clear the bores with 2.02s and 1.6s? The stock bore is 3.736. The valves themselves take up 3.62 and add the spacing between.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 04-09-2011, 10:53 AM   #8
my4by2
my4by2's Avatar
Good point & no - 305's do NOT need 2.02/1.60 valves.... Heck, some 350's don't even need that depending on application & actual head flow... If I did ANY valve work on a set of 305 heads it would of course be the quality valve job (3 angle is MORE than adequate) & maybe a slightly larger exhaust valve only since they are quite small on this head. Other than that just do a little port matching & maybe a little bowl blend & you'll be good.
Old 04-10-2011, 03:57 AM   #9
fast75
Go Hard or Go Home!
fast75's Avatar
i just ASSumed it would work, i went that route with my 350 with the port matching you mentioned. my block was decked, heads milled and the above mentioned valve work. i did have to go to pre-unleaded heads to stay out of the water jackets tho. sorry for any confusion i may have caused. my bad. i do know that it made all the difference in the world with my truck. damn thing will set you back it the seat and pass anything but a gas station.
