Old 03-28-2011, 01:03 AM   #1
C10CORIE
C10CORIE's Avatar
Will Coil Spring Rear Suspension out of 67-72 fit in a 65 Carryall?
I have a 1965 GMC Carryall that currently has leaf springs in it, but was wondering if the rear coil spring suspension out of a 67-72 would "BOLT"in to this rig??
Anybody ever try it??
C10CORIE is offline   Reply With Quote
Old 03-28-2011, 01:22 AM   #2
Captainfab
60-66 Nut
Re: Will Coil Spring Rear Suspension out of 67-72 fit in a 65 Carryall?
The coil spring suspension should bolt right in that '65 GMC. I believe the trailing arm crossmember should already be in there.
Old 03-28-2011, 09:22 AM   #3
YBNORML
YBNORML's Avatar
Yes and no, the arms will bolt in but you will have to build upper mounts for the coil springs.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
