new guy needs some help.
first post here, hopefully someone can help me out! I got me a long bed 65 chevy C-20 with a 350 rebuild and 2 speed tranny. I believe the problem is either coming from the fuse block, or a bad wire connection. First off, my truck will shut off and I wont hear the electric fuel pump running. There is two things I do to get it started again. 1. tilt the fuse block up and to the left and I can hear the fuel pump goin again (sometimes this wont work) 2. wiggle some wires til i hear the pump goin but the connection doesnt seem to stay.
Any ideas would be great! Ill try and get some pictures up asap. |
Re: new guy needs some help.
Loose connection at the fuse block?
You can "tilt" the fuse block? The fuse block is supposed to be mounted to the firewall. |
ya i figured that much. It came like that from the guy i bought the truck from. So how do i tighten that sucker up?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
has 2 bolts that fasten it to the firewall, one is just to the left of the hood hinge and the other is under the wheel well.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
thanks man, Ill let you know how it works out!
