Old 03-28-2011, 09:48 AM   #1
Law_Man
Law_Man's Avatar
Question?
I am new to this whole restoration thing. What does " the truck is mounted 3 inches off of the frame" mean?
2001 GMC Sierra Z71
1950 Chevy 3100
1952 Chevy 3100
My truck Build http://67-72chevytrucks.com/vboard/s....php?t=446958:
Law_Man is offline   Reply With Quote
Old 03-28-2011, 09:53 AM   #2
IwantaK5
Re: Question?
i would assume it means the truck has a 3 inch body lift. Which is basically the body mount bushings are 3 inches thicker than stock.
IwantaK5 is offline   Reply With Quote
Old 03-28-2011, 09:56 AM   #3
MrDude_1
Re: Question?
When its said on here, that usually means the cab/body mounts are located 3" higher then the top of the frame.
You will usually see this in the threads where someone is putting the truck body on a newer frame... like a S10 or Dakota.
MrDude_1 is offline   Reply With Quote
Old 03-28-2011, 10:06 AM   #4
Law_Man
Law_Man's Avatar
Re: Question?
Thanks I think I understand now
2001 GMC Sierra Z71
1950 Chevy 3100
1952 Chevy 3100
Old 03-28-2011, 02:38 PM   #5
OrrieG
OrrieG's Avatar
Re: Question?
Or 4wd that may have been lifted too. also involves lengtening brake lines, longer shocks, throttle linkage adjustment, brake and clutch pedel changes, sometimes shifter, and lots of minor stuff.
OrrieG is offline   Reply With Quote
