Old 03-28-2011, 10:13 AM   #1
MONTEZ
Anyone with a bell tech 5/7 kit on a square?
I am looking into this kit and was wondering if anyone out there has it and can give me a heads up on fitment. I hear you can run the 3" spindle without having to grind it to clear a 15" wheel. Can anyone confirm this? I plan to run 20's on this truck, but I'd rather wait till everything else is finished before putting a few grand down on wheels...
Any info or advice would be greatly appreciated.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 03-28-2011, 10:58 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Anyone with a bell tech 5/7 kit on a square?
A 15" wheel with more than 3.75" BS will need to have some grinding done to the lower a-arm.
No way around it.
(15x8 ralley wheels have a 4" BS)
There should be no grinding on the spindle itself.
(I have seen other brand spindles need grinding around the upper ball joint, or some auto parts calipers needing a little grinding due to excessive casting size)
Bigger rims will make these steps unnecessary.
I always trim the lower a-arms anyway,... just in case you have to throw the stock wheels back on.
Keith
Convert to disc brakes.
Old 03-28-2011, 11:52 AM   #3
franky69c10
chevy runs deep
franky69c10's Avatar
So 15x8 ralley's will work with 3" drop spindles without grinding the A-arms ?
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 03-28-2011, 11:58 AM   #4
lolife99
lolife99's Avatar
No.
Not without grinding.
They have more than 3.75" BS. (4")
Grinding is required.
Takes about 5 minutes per side to slighty trim the lower edge of the a-arm.
Keith
