Old 03-28-2011, 12:57 PM   #1
Puglia10
Cutting and powdercoating springs ??
Okay I know this topic is brought up a lot but I have a few questions I couldnt find the answer to....original front springs from an 80 2wd swb
-I want one inch drop in the front, is that half a coil or 1/4 of a coil?
-which end do I cut and with what tool?
-Is it okay to powdercoat them after or will that affect the spring at all?
Thanks!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 03-28-2011, 01:15 PM   #2
jimmydean
jimmydean's Avatar
Re: Cutting and powdercoating springs ??
Powedercoating will not hurt the spring at all. It's only heated to 400 in most cases and that isn't enough to change the spring rate.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-28-2011, 01:51 PM   #3
1970C10truck
1970C10truck's Avatar
I would start by cutting a 1/4 coil at a time and check them in the truck as you go and remember they will probably settle a bit more over time. Cut them with a cut off wheel. No cutting torches or plasma cutters.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
