03-28-2011, 01:16 PM | #1 |
Gas guage problems..
I thought I remembered seeing a thread on troubleshooting gas guage problems, but cant seem to find it so I thought I'd run my question by ya'll.
I have a 1987 silverado and the gas gauge shows 1/4 to 3/8 full when the tank is completely full. This is for both tanks. When it shows empty the tank is empty. Any idea where to start? Thanks for any help. Ryan |
03-28-2011, 03:00 PM | #2 |
Re: Gas guage problems..
This topic has a lot of discussion here, but it all boils down to:
Check the grounds from the sending units. Check the selector switch. Check the fuel gauge. If your gauge reads identically on both tanks, then I say go for the gauge. My take - remove/replace the gauge without getting dirty (takes about 20 minutes to check) - cost about $50-$60. Assuming you don't find any loose wires under the truck, this is the way I would go. |
03-28-2011, 03:30 PM | #3 |
Getting Old; Going Broke
Sounds like a good time to replace the sending unit to me. Your truck will probably thank you for the new pickup filter in the tank anyways. Just my .03 though (inflation).
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
03-28-2011, 03:39 PM | #4 |
03-28-2011, 04:00 PM | #5 |
Sending unit is what I'm afraid of lol. Lots of money to be spent on those. Thanks for the help guys, hopefully next weekend I can start trouble shooting.
03-28-2011, 08:51 PM | #6 |
Unfortunately that is more than likely the problem. The good thing, you should be able to take the bed off with a hoist and save the trouble of dropping the tanks. Highly recommended and also allows you to work comfortably!
03-28-2011, 09:19 PM | #7 |
Both sending units go bad at the same time? If so, maybe it is the gauge. If you can get your hands on a known working gauge to temporarily replace yours, that will save you the hassle of dropping the tanks (assuming the sending units are OK.) Of course, check the grounds on the sending units first.
Aftermarket Spectra brand sending units are about $40-$50 each, but they cause the gas gauge needle to bounce on acceleration, stopping, turns, etc. AC Delco gauges don't do that, but they are about $140-$160 each. |
03-28-2011, 09:30 PM | #8 |
Robert Olson Transport
check the grounds before you do anything those are the usual culprits on stuff like that
03-28-2011, 09:47 PM | #9 | |
Moderator
03-29-2011, 10:59 AM | #10 |
03-30-2011, 04:24 AM | #11 | |
Moderator
Here's a link to some discussion on an electronics board about building a simple anti-slosh circuit for a 1960's Italian car. http://www.discovercircuits.com/ubbt...er=6590&page=1 I would guess GM used mechanical damping on the actual movement of the sender arm. F*&d used a simple circuit on the gauge panel with cheaper senders. |
