Old 03-28-2011, 04:56 PM   #1
Barney Rubble
Barney Rubble's Avatar
59 6 bolt IFS?
Does anyone make a 6 bolt IFS for 59 apache 3100? I have looked at plenty of websites, and they all seem to be a 5 bolt pattern.
The wheels I have at present are 6 bolt so would like to stick with that if possible.
OR
would I be better off going to 5 bolt? Are the wheel choices better?
BR
Barney Rubble is offline   Reply With Quote
Old 03-28-2011, 05:07 PM   #2
jimig1
jimig1's Avatar
Re: 59 6 bolt IFS?
TCI has a 6 bolt upgrade
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 03-28-2011, 05:17 PM   #3
Scottshotrods
Re: 59 6 bolt IFS?
Scotts Hotrods has a 6 lug upgrade as well and we have great forum deals for all of the great people on this great site.
Justin
Scottshotrods is offline   Reply With Quote
Old 03-30-2011, 09:29 PM   #4
chopsspcc
Re: 59 6 bolt IFS?
there is a place in Bedford, PA I think it's www.martzchassis.com
chopsspcc is offline   Reply With Quote
Old 03-31-2011, 03:51 AM   #5
Barney Rubble
Re: 59 6 bolt IFS?
Justin
Thanks Justin.
From the looks of it, seems 5 bolt is the way to go, certainly more options there, and at a keener price than the 6 bolt, also sounds like a valid reason for new wheels!
Old 04-02-2011, 06:10 PM   #6
Red Foreman
Red Foreman's Avatar
Re: 59 6 bolt IFS?
If you Camaro clip your truck you will struggle to find 6 lug rotors, I chose to keep mine because I wanted to run steelies & I think 6 lug have a little cool factor, but thats just my opinion. This is how I did mine.http://http://67-72chevytrucks.com/vboard/showthread.php?t=437842
Red Foreman is offline   Reply With Quote
Old 04-02-2011, 08:11 PM   #7
mobileortho
mobileortho's Avatar
Re: 59 6 bolt IFS?
You might also consider the IFS from a 63-70 C10. It will bolt right up to your frame with no modifications and the best part is that you can pick one up cheap! I used on from a 79 on my 3600 but had to have it narrowed to make it fit but you wont have that problem siince you have a wider frame.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 04-02-2011, 10:27 PM   #8
chopsspcc
Re: 59 6 bolt IFS?
do you have anymore pics of that swap you did? It actually bolted on? No welding or anything?
Chops
Old 04-02-2011, 11:45 PM   #9
sandnuriz
sandnuriz's Avatar
Re: 59 6 bolt IFS?
[quote=mobileortho1;4596057]You might also consider the IFS from a 63-70 C10. It will bolt right up to your frame with no modifications and the best part is that you can pick one up cheap! I used on from a 79 on my 3600 but had to have it narrowed to make it fit but you wont have that problem siince you have a wider frame.
Chops
I was thinking the same thing! Bolted right up that sounds nice more info please.
Also Six lug is the way to go for wheels all the 02 and newer 2wd trucks are 6 lug I could be wrong about the year they started doing 6 lug on the 2wd for newer body style but a buddy of mine owns a wheel shop and never has a problem getting six lugs wheels almost any style
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 04-03-2011, 06:03 AM   #10
Barney Rubble
Re: 59 6 bolt IFS?
5 or 6?? decisions.
Old 04-03-2011, 03:44 PM   #11
kaycee
kaycee's Avatar
Re: 59 6 bolt IFS?
Well OK Ill go out and measure my 69 C-10 with the 74 front and get back to ya. I would measure the 58 but we got a coupla inches of snow and still snow/rain .OK ran out and measured I got 28" outside frame/outside frame this is allso confirmed through the service man.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-03-2011, 05:57 PM   #12
mobileortho
Re: 59 6 bolt IFS?
Chops
That's correct. You could weld it up if you choose, but there's really no need to since that's the way GM designed it to work. If I recall, the entire unit is held in place by ten bolts. You can find detailed instructions here.
Robert C.
1950 3600
Old 04-03-2011, 06:17 PM   #13
mobileortho
Re: 59 6 bolt IFS?
Originally Posted by Barney Rubble View Post
5 or 6?? decisions.
The six lugs were used through 70 & the five lug I know for sure through 87 but beyond that, I'm not sure but they are all bolt on.
Robert C.
1950 3600
Old 04-03-2011, 07:01 PM   #14
Barney Rubble
Re: 59 6 bolt IFS?
I envy you guys having a larger reservoir of options than we have here, costs are also in your favour.
All good info, keep it coming.
Old 04-03-2011, 11:39 PM   #15
kaycee
kaycee's Avatar
Re: 59 6 bolt IFS?
I been thinking of doing this swap myself,The AD frames are narrower than the TF trucks correct?If I remember correctly the TF frames are 34" wide
2005 FXDWG stage3
63 IMPALA 327
Old 04-04-2011, 08:07 PM   #16
mobileortho
Re: 59 6 bolt IFS?
That's correct. It's a direct bolt on for the TF trucks.
Robert C.
1950 3600
Old 04-06-2011, 09:37 PM   #17
kaycee
kaycee's Avatar
Re: 59 6 bolt IFS?
OK how did you do it I measure my front end of 69 with front end from a 74 it measures 28 1/2" the 58 is 34".Not trying to be a di@# but just trying to find the answer
2005 FXDWG stage3
63 IMPALA 327
Old 04-07-2011, 12:25 PM   #18
mobileortho
Re: 59 6 bolt IFS?
You are correct. For my AD it was a bolt on affair but had been told by others that they did this swap on their TF. Did some research and came across this article detailing the steps to do the install the IFS on a TF.
Robert C.
1950 3600
