Old 03-28-2011, 05:32 PM   #1
big10charlie
Unhappy power window switch
Both windows in my 78 are stuck down!!! I have power to the switch on the drivers side but no go for the windows? Is my switch bad? if so where does a guy find the power window switch that has 5 prongs on the back? everyone ive found is 6! Please help!!!
big10charlie is offline   Reply With Quote
Old 03-28-2011, 05:43 PM   #2
eightyfive
eightyfive's Avatar
Re: power window switch
it could be your window motor. im no expert though.
parts truck- 1982 suburban GMC Sierra Classic
first project- 1985 GMC Sierra Classic
first truck- 1988 GMC Sierra sle
"New" Hot rod 1999 Chevy silverado 5.3L
Workin my way up the food chain
eightyfive is offline   Reply With Quote
Old 03-28-2011, 05:46 PM   #3
turner16
Check for power at the motor, while pushing the switch with the key turned. If you have power then your motor may be stuck. Just take the plug out of the motor
turner16 is offline   Reply With Quote
Old 03-28-2011, 05:57 PM   #4
big10charlie
I have power at the motors. But lose it when you push the switch! Both windows are stuck down as well!
Old 03-28-2011, 06:28 PM   #5
turner16
then you have a short in the switch. You should have + one way and - the other wire the switched when the switch is reversed. + where the - was and vice versa.
I'm still struggling with mine too.
Old 03-28-2011, 06:54 PM   #6
dswancutt
there is a relay under the dash on the 77-80 models you might need to check. Mine was bad and had been hacked around. If it is bad, do an eBay search for 3996804.
dswancutt is offline   Reply With Quote
Old 03-28-2011, 07:08 PM   #7
turner16
isn't that relay for the locks only
Old 03-29-2011, 07:59 PM   #8
big10charlie
thats what I thought that relay was for! Im not sure though I just pulled it out of winter storage today so its time to do more investigating!
Old 03-29-2011, 08:16 PM   #9
dswancutt
Only the years 77-80 had the relay under the dash. I have a 78 which had a bad one that someone had hacked around.
Old 03-29-2011, 11:27 PM   #10
big10charlie
so what am I looking for under the dash?
Old 03-29-2011, 11:54 PM   #11
dswancutt
here is a picture of one from ebay
http://67-72chevytrucks.com/vboard/n...te=1&p=4587657
It has has a 3 wires going to it, one large red/white, a pink/black and a orange/black
Old 03-30-2011, 11:42 AM   #12
big10charlie
where under the dash is it located? I must be blind!!
Old 03-31-2011, 09:31 AM   #13
big10charlie
well heres the update! Windows are up and it was a faulty relay under the dash!!! Now where am I gonna get one of those at? local parts stores looked at me funny! I have it hot wired so they go up and down for the time being! Thanks for the help guys!
Old 03-31-2011, 09:37 AM   #14
babyJay
Arrived on a Pale Horse
babyJay's Avatar
you could probably put a universal 12V relay in there if you can't find one.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-31-2011, 10:18 AM   #15
dswancutt
Here is the eBay link I wanted to post, but screwed up.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 03-31-2011, 10:50 AM   #16
big10charlie
WOW! thanks for locating that! that relay was used for other purposes i see!
Old 03-31-2011, 10:55 AM   #17
dswancutt
I think that is the guy I purchased mine from. It came in the original box. You have probably figured out you have to bend yourself into a pretzel to get to the relay
The mental giant who worked on my truck before I had it cut off the connector to put in an aftermarket relay so that is on my todo list.
Old 03-31-2011, 01:55 PM   #18
big10charlie
and to think that all of the trucks I parted out that had power windows in them I never even thought of taking any of those relays from under the dash! This site is so very helpful! Now the next step is to get my cargo light to work again! Thanks again for all the help!!http://www.facebook.com/album.php?id...783531&theater
