![]() Join Date: May 2010
15x6.5 rally wheels
Anyone running these? Looking for pics on some trucks?
Thanks! |
Re: 15x6.5 rally wheels
Hmmm. No one is running rally wheels in 15x6.5 on this site?
I've never heard of or seen such a thing. i only know of 7" and 8".
Fabricate till you "puke"
I have a pair on the front of my Longhorn, but run 8" on the rear....Ill try to get you a pic. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Special-K, the van ralleys are 6.5 wide. Sorry, a little computer illiterate, but if you go to web shots, & look under albums, dig up hotrodhorn....you will find a few pics on the ralleys(and a long /sawed off truck). crazyL
15x6.5 front
15x8 rear
Thanks for squaring me away on that. I think I made the same mistake before on this. I thought Vans had 7s. I'll have to let it stick this time
![]() Join Date: Apr 2010
15x6.5's on front, 15x8's on rear.
will the deep dish trim rings fit the 6.5 rims? i have 6.5 on front 8's on the rear, but i need the trim rings.
thanks |
I don't think so (not enough 'lip'). I use the 88-98 Chevy/GMC truck trim rings on all my 15" steel wheel that get rings & caps.
What size tires are you all running on the 6.5" rims?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
205, 215, 225-75-15's
215-70-15's The 255-70-15 or 275-60-15 on the 8" truck ralley are a nice match if you like the staggerd look.
#13 |
My truck currently has van ralleys on all 4 corners ,but its in the body shop .When it comes home it will get 8" ralleys on all 4 corners .
