Old 03-28-2011, 08:39 PM   #1
NobleSix
Question clutch adjustment
hello everyone. i have a 69 c10 longbed with a 292 inline 6. the engine was a donor because the first one had a cracked block and head. i didnt have the money to buy a new clutch assembly so i re used the old one. as far as i know its not hydraulic. i didnt mess with any of the linkage settings under the dash or from the fork ect...but the clutch pedal goes all the way to the floor with very little resistance and disengages the clutch about an inch or so from the floor. its a 4 speed manual granny tranny. im still kinna new to all this, and im wondering where i should start.
also i was wondering the best way to burp all the air out of the coolant system, and if i could mount a temp gauge sending unit in the thermostat housing itself cause my cyl head dosent have a port for it.
thanks for taking the time to read this.
NobleSix is offline   Reply With Quote
Old 03-28-2011, 09:36 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: clutch adjustment
ttt for ya
ETsC10 is offline   Reply With Quote
Old 03-28-2011, 11:17 PM   #3
68gmsee
Active Member
68gmsee's Avatar
First thing you need to check is the clutch linkage adjustment. The clutch should start to make contact with the throw out bearing/pressure plate 1/2" to 1" from the top (free play). About half ways through the travel it should disengage the clutch from the flywheel and pressure plate.
There's a lock nut and link adjustment to do that. If you are at the end of the adjustment and everything is original and hasn't been changed then you may have extreme wear in the clutch/pressure plate and they will have to be replaced.
68gmsee is offline   Reply With Quote
Old 03-29-2011, 01:27 AM   #4
NobleSix
thankyou, ill start there tomorrow morning
