70 c20 help
What's up guys & gals! I recently got two trucks off my uncle; one is a 76 c 20 with 84,00 origional miles. The body is really rough, but mechinacal is good. The a/c still works! The other is a 70 c 20. This is where my intrest is. How can I tell what size engine is in it, without pulling it. It's a SBC with a 1 barrel carb, and the oil filter looks like a cartridge filter inside a chrome canister mounted on the passenger side inner fender well. It's got a granny 4 speed trans. Where can I find reasonable body parts at? I already know of LMC from my previous project 86 truck. Thanks for any help!
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: 70 c20 help
On the back of the block, behind the driver's side cylinder head is a flat area with a number stamped in it. You will have to nearly stand on your head to see it. Usually requires a wire brush, some carb cleaner and a rag, to get it clean enough to read, plus a flash light.
Bring the results back here. ![]() . Last edited by ETsC10; 03-28-2011 at 09:33 PM. Reason: tyyypooo |
