Old 03-28-2011, 10:10 PM   #1
BIG D 85 gmc
Ls swap ?
I know this has been asked before but i cant find nothing im looking for some tubed motor mounts for a ls swap i would also like to be able to use long tubes with the engine im gonna use a ls1
BIG D 85 gmc is offline   Reply With Quote
Old 03-28-2011, 10:20 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Ls swap ?
Welcome to the board Big D!!!!
We have a special area for the LS swaps, so I'm
going to transfer you over to the Gurus!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 03-29-2011, 07:22 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Ls swap ?
Welcome, here are the two I know of.
POL
http://www.performanceonline.com/Engine-Mounts-c-455/
CPP
http://www.classicperform.com/6092chevtrk.htm#40
For headers, check out the Tri-ys. Shon on here has them.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-29-2011, 11:08 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Ls swap ?
what are you going to put the LS into?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-29-2011, 12:20 PM   #5
BIG D 85 gmc
Re: Ls swap ?
I JUST RECENTLY BOUGHT A 68 SHORT WIDE
Old 03-29-2011, 01:21 PM   #6
Clyde65
Clyde65's Avatar
Re: Ls swap ?
Oh, Ok, sorry I didnt know.
You can go with the POL ( I did) means you can have the motor set back or forward. They would be fine with long tubes, although I have shorties. ECE has a good product also that I dont think are adjustable though.
Also you would possibly need a trans crossmember, unless you are using your stock 3speed. you can put the motor in with the 3speed tranny and you can use your stock 3speed cross member and mount. There I would suggest the POL perches.
Stock perches can be used, several guys have, makes the pan sit lower though.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-29-2011, 05:00 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Ls swap ?
I'm using the stock perches and mounts, with adapter plates. It sets the engine almost into the firewall, so I fabbed it so the perches sit about 2.5" forward (where the "front" holes on the frame are). The engine sits fairly low, with the pan and xmember being almost level to each other. This is an lq4 so it stands a bit taller than the ls manifold.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-30-2011, 08:30 AM   #8
BIG D 85 gmc
Re: Ls swap ?
POL
CPP
Do those POL bolt up to the stock holes
Old 03-30-2011, 10:08 AM   #9
Clyde65
Clyde65's Avatar
Re: Ls swap ?
Yes, they will. The POL ones mount to either front or rear holes. The CPP ones will ONLY mount to the front holes.
ECE ( Early Classic Ent) has one that is similar to the 73-87 ( I think) perch, it will also work.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-30-2011, 12:54 PM   #10
BIG D 85 gmc
Re: Ls swap ?
So did you redo your own harness or did you buy a plug n play, iv'e been trying to get a hold of Nelson Performance to see how much there harness is but can't seem to get a hold of themany suggestions on where to get one and at what price
Old 03-30-2011, 12:59 PM   #11
Clyde65
Clyde65's Avatar
Re: Ls swap ?
Nelson has a great product, I had a performance tune done by them, great job. I do think their harness is a little too high. I would go with these guys, many good reveiws from here on them.
http://www.lt1conversion.com/products.php
BTW, did you get the stock harness and the DBW pedal, PCM and all that from donor vehicle?
I had wait4me performance do mine, it is ugly but works, at least until I can afford the LT1 harness it works.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-30-2011, 01:18 PM   #12
BIG D 85 gmc
Re: Ls swap ?
then i would need to get a msd box for the coils right, or would the harness take care of that
Old 03-30-2011, 01:31 PM   #13
Clyde65
Clyde65's Avatar
Re: Ls swap ?
their harness will have everything you need, all you will need to "hook up" is three wires I believe, maybe four. If your PCM is tuned, then hook up the wires and it will start.
Clyde65
Rebuild of Clyde
support our troops!
