Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-28-2011, 11:37 PM   #1
Yellow76
Yellow76's Avatar
sbc break in
Well finally got my motor all ready to break in so started it running fine but after about 4 min at 2000rpms my temp gauge isnt going up so i shut it down thinkin sonethings wrong. my headers are red hot so shouldnt my temp gauge be reading something i have a new 4 core and dual fans i just had them going full blast what do you think?
Yellow76 is offline   Reply With Quote
Old 03-29-2011, 11:55 AM   #2
1970C10truck
1970C10truck's Avatar
Re: sbc break in
If your headers are glowing I would say advance the timing. I did that once because I was trying to do it alone and I didnt want to stop on the break in and lose the cam. I got out and looked at the motor for a second and the headers were so red it looked almost transparent. start it up rev it to about 2500-3000 RPM and have someone set the timing to 34-36* while its running. Should cure the problem.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 03-29-2011, 07:47 PM   #3
fryco
fryco's Avatar
Re: sbc break in
Make sure your carburetor isn't flooding over. Floats set to high or too much fuel pressure will turn the headers red quick! Smell your oil, you can smell raw gas when their real rich...
fryco is offline   Reply With Quote
Old 03-29-2011, 08:51 PM   #4
shortbed70
shortbed70's Avatar
Re: sbc break in
Our dirt cars did that when they were lean or not enough fuel.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-29-2011, 10:11 PM   #5
Robertjust777
Re: sbc break in
check and make sure thermostat isnt stuck
Robertjust777 is offline   Reply With Quote
Old 03-31-2011, 12:38 AM   #6
Yellow76
Yellow76's Avatar
Re: sbc break in
alright well i got it warming up fine needed a themostat but i noticed some of the cylenders are hotter than others like the tube coming out of #2 is alot more blue than any of the other cylenders on that side of the motor. Could this be due to adjusting valves wrong or the timing because this is still a brand new motor
Old 03-31-2011, 11:24 AM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: sbc break in
Originally Posted by Robertjust777 View Post
check and make sure thermostat isn't stuck
I agree. Also check water pump to see if it is flowing correctly.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-31-2011, 02:39 AM   #8
Super73
Super73's Avatar
Re: sbc break in
I wouldn't go off color of tubes, but using a heat sensing gun on each tube of the header is much more effective and accurate (they are cheap at harbor freight). But if this an issue it could be intake design and unequal fueling, unequal cranking compression due to a valve open or rings not seated completely allowing blow by. Just a few thoughts.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
