03-28-2011, 11:42 PM | #1 |
anyone have pic's on a 5 inch drop?
I lowered the front 3 inches front and 4 rear i wanna go lower in the front to 5 inches and 6 rear I dont want to bag so if anyone has pic's on this i would really like to see them!! anyways thanks for the help.
03-28-2011, 11:55 PM | #2 |
Re: anyone have pic's on a 5 inch drop?
I will have some pictures posted tomorrow night of my truck. It is 5 in the front and six in the rear. It will give you an idea though. It has 18's and 20's.
03-29-2011, 06:52 AM | #3 |
heres my 66 c10 with a 4 1/2 and 5 1/2 drop on 22's
03-29-2011, 08:45 AM | #4 |
and a few others
You may want to reconsider. That's just too low for a static drop with stock A-arms...
http://67-72chevytrucks.com/vboard/s...d.php?t=442767
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi Last edited by 63 & 64 Bowties; 03-29-2011 at 06:09 PM. Reason: felt like havin a peanut butter & jelly sandwich |
03-29-2011, 08:54 AM | #5 |
03-29-2011, 09:04 AM | #6 |
3" springs up front with a coil cut off and 5" springs with 2" blocks in rear.. No scrubbing problems... Except tailpipes..
03-29-2011, 09:12 AM | #7 | |
Guys running deep "cupped" lower a-arms and rear lowering blocks should take note. The term "Scrub Line" comes to mind. Last edited by lakeroadster; 03-29-2011 at 02:54 PM. |
03-29-2011, 10:05 AM | #8 |
03-29-2011, 10:36 AM | #9 |
and a few others
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
03-29-2011, 02:40 PM | #10 | |
" The lesson is in the struggle , not in the victory " |
03-29-2011, 05:38 PM | #11 |
03-29-2011, 06:07 PM | #12 | |
and a few others
This is also a problem on '63-'87 Chevy Pickups that have been lowered more than 4" The lower control arms get REALLY close to the ground with any more drop. Two guys here in town have gotten hooked the same way as the subject '55. There are ways to lower the truck more, but they are going to involve more bucks, as the entire suspension will get replaced, but gaining a couple inches ground clearance, and a slightly narrower track for tire clearance.
03-29-2011, 06:14 PM | #13 |
I can definately vouch for that. Leaving downtown Pittsburgh one day I was cruising real low and all of the sudden heard WHAM and came to a complete stop. Turns out there was a steel plate in the middle of the road that I decided needed moved about 3" or 4" infront of me. It hit the control arm stopping me in my tracks and moving the plate. Luckily I did not damage the frame or crossmember (bent the shlt out of the control arm though) but to resolve the issue I did get a chopped crossmember which will bring the center of the truck (control arms and all) up 1 1/2". This should resolve the issue and give me another 1.5" drop when I am all aired out.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
03-29-2011, 10:42 PM | #14 |
5" front/6" rear drop:
Currently blown apart for paint and a full resto. Boxing the CPP C-notch right now. Early Classic 2" drop spindles, 3" drop springs and a CPP sway bar up front. Early classic 6" drop springs along with an EC adj. panhard bar and shock relo kit, Hellwig sway bar out back. KYB drop shocks all around. Later model PS, PB and front discs. Auburn posi. Poly cab mounts. Handles great.
The dude abides. |
03-30-2011, 02:33 AM | #15 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by Liz; 03-30-2011 at 08:12 AM. Reason: classified ad |
03-30-2011, 06:11 AM | #16 |
here's mine ,5" springs in rear...3" springs in front with 2 1/2" drop spindles...
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
03-30-2011, 07:09 AM | #17 |
Here's mine with 5 in the front and 6 in the rear!
03-30-2011, 09:29 AM | #18 |
It rides just fine.. I cut the bumpstop mounts off.
03-30-2011, 10:50 AM | #19 |
03-30-2011, 11:04 AM | #20 |
Thank you.. 255/60/15 rear with 8" wheels and 235/60/15 up front with 6" stock wheels..
03-30-2011, 11:06 AM | #21 |
[QUOTE=Blue Heeler;4588418]What size tires you running on that bad boy? looks good. Ive been running it this way for about 4yrs
03-30-2011, 11:06 AM | #22 |
Also remember you will need a rear notch if you go lower than 5" in the rear..
03-30-2011, 11:42 AM | #23 | |
It's Better With Nitro
...the issue... If you want that much of a static drop, I would highly recommend investing in a Porterbuilt front suspension system.
03-30-2011, 03:08 PM | #24 | |
My truck is around 4" or 5" in front and 6" in back. I measured from the center of the hub to the fender lips to compare drops (It takes tires size out of the equation).
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-30-2011, 03:32 PM | #25 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 03-30-2011 at 03:38 PM. |
