03-29-2011, 12:06 AM | #1 |
do i need to box my frame
Hey I was wondering if I need to box my frame for a street and strip truck with a 496 and about 650ftlbs of torque and 650 hp
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
03-29-2011, 02:21 AM | #2 |
Re: do i need to box my frame
I run a stock frame and don't have a cage yet. But I'm not making that much TQ. Just 550hp/500ftlbs at the tires with the old combo on 1 stage.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
03-29-2011, 06:29 AM | #3 |
I should have specified that it is 650 at the crank so I should be fine
03-29-2011, 12:00 PM | #4 |
If you can get the frame stiff as possible it willprobably help to make the truck more consistent to suspension changes. If everything is solid the suspension is doing the work rather than the frame. Just my 2 cents.
1970 C10 swb 350 4spd under construction |
03-29-2011, 04:37 PM | #5 |
good to know
03-30-2011, 10:08 AM | #6 |
Mine is not boxed, but I have a cage that is certified to 7.50. my engine is an 540 BBC, on 2 systems. 1.34 60' times, 5.50 @ 130 1/8 mile. The cage is sufficient. Paul
03-31-2011, 11:30 AM | #7 |
"Where were you in '62?"
How is you rear suspension setup?
http://www.competitionengineering.co...s/chassis2.asp
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
04-02-2011, 03:47 PM | #8 |
It's not that hard to do and its cheap insurance. If you have a cage I don't think you will need it. I'm running a Duramax diesel witch weighs about the same as a big block but it dynoed 1250ftlbs at the wheels last year and should have about 1400ftlbs this year. I don't have a cage but did box my frame and I've had no problems.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
04-27-2011, 05:35 PM | #9 |
If you have it apart, now is the time to do it. It is better than second guessing and wishing you had done it later. I boxed a pro-street truck with a lot less torque.
It is a great excuse to get a quality plasma cutter if you don't already have one. If you already have one, get some plate steel and get busy! |
04-28-2011, 03:27 AM | #10 |
Your choice. IMO, the weight isnt worth it. I just boxed a 6inch section where my watts link attaches and thats it. These are not weak frames. They are plenty thick to hold any power if you have a cage. I highly doubt they would flex or bend without a cage. Like some have said they are in the 9, 10 sec and not boxed.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-28-2011, 10:51 AM | #11 |
It's Better With Nitro
Is your frame currently modified with any of the cross members removed or the frame notched? Have you removed the inner fenders? If not, you may not need to, but it does depend on what your ET goals are.
04-28-2011, 12:19 PM | #12 |
There are 2-3 guys here running deep 9's and faster with out a boxed frame with a cage. One of which commented in this thread advising it is NOT needed. I tend to agree that the cage will stiffen it up, even more so than boxing the frame will. Boxing the frame is just going to add weight and slow you down.
04-28-2011, 03:02 PM | #13 |
being that theoretically 200 pounds in a car with a thousand hp slows the car down by .24 seconds, boxing the frame in my opinion is just a little reassurance. the plate to box the frame from the rear all the way to about a foot from the trans x-member only weighs 80 lbs if 1/4" is used.
04-29-2011, 12:11 AM | #14 |
60-66 Nut
If any boxing would be done, I'm thinking just a small section where each cage tube is welded to the top flange of the frame, just to add ridgitity to the top flange. And there is absolutely no reason to use 1/4" plate. We're not talking about a semi here, 10 ga. would be just fine.
04-29-2011, 05:45 AM | #15 |
Mine is not boxed.. And i plan on spraying mine, will put it in the low 10's. Cage comming soon....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
