Old 03-29-2011, 09:20 AM   #1
Trac-Loc
Does anyone run one of these or have any past experience with them? If so,what vehicle,tire size,etc?
Old 03-29-2011, 06:46 PM   #2
Mike C
Mike C's Avatar
Re: Trac-Loc
Is that for a 60? I've got a couple of them, but sold my truck before I installed one. They are an OK choice for a street driven limited slip. Use Belleville springs for clutch pack pre-load and they have a reputation for wearing reasonably quickly.
Dollar per dollar, least expensive way to get a clutch type limited slip in a Dana 60. The Powerlock is the preferred Dana limited slip, but they are three times the price. 3 times as good? Arguably I guess, but I have no qualms about installing and running one FWIW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-30-2011, 09:34 AM   #3
Re: Trac-Loc
The one I have is for a Dana44 front. I got it used and very reasonable. I figure for the front and nothing extreme it would be a nice enhancement,especially with a Power-loc Dana60 in the rear.
Old 03-30-2011, 02:42 PM   #4
Mike C
Mike C's Avatar
Re: Trac-Loc
Awesome. Would definitely install it in a front over an open diff.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-30-2011, 03:08 PM   #5
JimmyFloyd
Re: Trac-Loc
interested in this as well, as I have one in my old suburban front D44HD that I am waiting to get back from the truck.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 04-02-2011, 05:16 PM   #6
68chevyfuelie
68chevyfuelie's Avatar
Re: Trac-Loc
As said above, they tend to wear fairly quickly. If you can, take it apart now and check out the clutches and the side gears. Look for wear on the side gear splines, and look for wear where the Belleville washer rides. Because all the pressure rides on that contact surface, thats where you will see the most wear.
They are kind of tricky the first time through one, but it's just time. You can make all the tools they list, you shouldn't have to buy any tools to rebuild one of these.
http://www2.dana.com/pdf/5313-3.pdf
68chevyfuelie is offline   Reply With Quote
Old 04-02-2011, 06:31 PM   #7
Re: Trac-Loc
Thanks,that's really helpful. At least in the front it shouldn't wear so fast
