New C10 owner with lowering question
I just bought my 69 2 weeks ago. It has the drum brakes still on the front. I want to do a mild drop on the truck since it sits like a 4X4. The truck sits fairly level and from the ground to top of the wheel wells is 38". I know I can do a 3" drop spring for the front but what about the rear? It is coil springs as well. To keep it level go with a 3" in the back? Was thinking a 3/5 but would the back end be lower? Thanks for any info as I have never had a C10 but finnally got one.
1952 Chevy 3100 1969 Chevy C10 2006 Chevy 1500 |
Re: New C10 owner with lowering question
Tj jeep coild drop it 4 in the rear........u can cut 2 rounds out of the front and get 4"
The TJ coils, do I need rear coils off a TJ? Do they bolt right in?
Yes u need rear and as far as i kno they bolt right in
They do bolt right in, and you can find them easily and inexpensive. $20 for mine, but if you plan to use your truck to carry or haul they are not a good idea. They bottom out fairly easily.
Posted via Mobile Device |
Thanks for the info!
