03-29-2011, 01:05 PM | #1 |
couple of ?????
i have a 61 chevy short wide big back window. will a dash from a 64 fit in it. and what is a good tranny for this it has a sb 400 now with the old power glide, how much trouble is it to swap to a t350 or 400 or even a 700r4.
03-29-2011, 01:24 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: couple of ?????
changing the dash is a monumental task because the dash is bolted on the sides but spot welded to the cab at the windshield, I dont know if the 64-66 dash would work because of the 60-63 dogleg cab configuration. how far along are you in your investigation
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-29-2011, 02:45 PM | #3 |
Check The Champ, Demonstrator
Re: couple of ?????
In order to clarify, would you be speaking of the entire dash that's welded to the cab or the instrument panel that screws into the dash that contains your gauges?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-29-2011, 03:13 PM | #4 |
Re: couple of ?????
i havent started yet but i did not know it was welded to the cab , it was just a thought, because i changed the hood , i didnt like the two big openings in the front, and thought it would look better if the dash matched. thanks for the info, so far i have a front disc brake crossmember to switch out and new rear end so the bolt pattern will be 5 on 4.75. other future plans include a duel 3 inch exaust and gear drive, also airbags for the rear and drop spindals for the front.
03-29-2011, 07:27 PM | #5 |
1961 crewcab
Re: couple of ?????
a 60-63 gmc dash would be a solution, a 6456 would require some fabrication...
either way you will have to weld it in under the w/s gasket
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-29-2011, 07:50 PM | #6 |
Senior Enthusiast
Re: couple of ?????
Not sure if you’re aware but the stock disc brake rotors have a 5x5” bolt circle. If you want the 4 ¾” passenger car pattern CPP can offers a kit:
http://www.classicperform.com/Instru...DF/6062DBK.pdf Here’s a thread that might be helpful if you’re swapping in a 73-87 crossmember: http://67-72chevytrucks.com/vboard/s...d.php?t=366850 I thought I was the last guy around that still enjoyed the sound of a gear drive. I’ve had a Pete Jackson noisy drive for almost 20 years. |
03-29-2011, 10:42 PM | #7 |
Re: couple of ?????
Do you still have the original hood and would you be interested in selling it?
03-30-2011, 12:57 AM | #8 |
60-66 Nut
Re: couple of ?????
Since you have a '61 with the X-member frame converting to a TH350 or TH400 isn't as easy as it is on a '63 and up truck. Did the truck originally came with the powerglide. Either way the current trans crossmember will need to be modified. If you decide to go with the 700R4, be very, very certain that the TV cable is adjusted correctly, and that you have the TC lockup operational. If the TV cable isn't setup correctly, you will burn up the trans very quickly.
03-30-2011, 01:22 AM | #9 |
Senior Enthusiast
Re: couple of ?????
Here's a thread about installing a TH350 in a 1960, showing the factory automatic transmission crossmember. A 700R4 would require a custom crossmember, but at least this might provide some ideas:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663 |
03-30-2011, 12:38 PM | #10 |
Re: couple of ?????
thanks for all the suggestions, as always very helpful. NWGREASER sorry i dont have the original hood it came that way. i think it came with the tranny because there is no clutch pedal. does anybody know what is a good set of headers for the 61 frame. and yes i was wrong about the bolt pattern i am changing it to the newer truck pattern 5x5.
