Old 03-29-2011, 01:26 PM   #1
52 Rat
52 Rat's Avatar
What firewall mount brake pedal assembly for 52AD?
I am racking my brain trying to find a firewall mounted brake pedal assembly for my 52. I've seen several build projects with power booster/pedal assemblies but can't make out the style or vehicle they came out of. Any help is greatly appreciated.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 03-29-2011, 02:22 PM   #2
weldvair@embarqmail.
Re: What firewall mount brake pedal assembly for 52AD?
I used GM G body.......Don
weldvair@embarqmail. is offline   Reply With Quote
Old 03-29-2011, 02:30 PM   #3
52 Rat
52 Rat's Avatar
What fabrications did the G body set up require? Any details or photos?
Old 03-29-2011, 05:37 PM   #4
flatbed51
flatbed51's Avatar
Mine is from a 1980 Malibu.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 03-29-2011, 06:08 PM   #5
BlueJeep
BlueJeep's Avatar
I think you've asked me about my s10 setup before. It's all apart now so let me know if you want more detailed pics of how I did it. Also I'd mention that you're looking for 3 pedals and not 2.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-29-2011, 08:41 PM   #6
52 Rat
52 Rat's Avatar
Yes, I have inquired about this before. My set up has changed. I no longer need all three pedals. I now have a Wilwood clutch pedal and master cylinder. I also have a brake pedal out of a late model HD Chevy. It has a integrated throttle pedal. The HD brake pedal assembly will not fit with a lot of fabrication. I can make the HD throttle pedal work.
I have looked at several S10 pedals and they look very short. Maybe the S10 brake pedal will work after all. I'm ready to set up the brake pedal and need something as soon as possible.
Old 03-29-2011, 09:41 PM   #7
BlueJeep
BlueJeep's Avatar
I think whichever way you go, you'll want to match the brake pedal and the booster/master out of the same vehicle, so you don't have to mess with bolt patterns and pushrod changes. I assume the HD you have the pedal from had hydroboost.
Maybe since you have the wilwood clutch pedal and master, their brake pedal and master would match and look better than something else.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-29-2011, 10:09 PM   #8
52 Rat
52 Rat's Avatar
I've been looking at Wilwood brake pedals and master cylinders. I definitely want a matched set up in regards to the pedal assembly and master cylinder. I'm not sure if the HD had a hydroboost or vacuum assist. A friend gave me the pedal assembly. Most HD's had a hydrobost but I've see vacuum assist on some. I have a 2500 HD 6.0 and it has a hydroboost set up.
Old 03-30-2011, 07:01 PM   #9
Dan Bowles
AD Addict
I have S10. They are a bit short but you get used to them in a minute. And 3 pedals are always better.
Dan Bowles is offline   Reply With Quote
Old 03-30-2011, 07:24 PM   #10
52 Rat
52 Rat's Avatar
I'm not sure if the S10 clutch master cylinder would be strong enough for the T56 slave bearing. I found a S10 with all three pedals.
Old 03-30-2011, 10:49 PM   #11
Dan Bowles
AD Addict
Why wouldn't it be strong enough? Make sure it is a 1:1 ratio and it is fluid in, fluid out. It is still a truck slave and they did put NV3500s with the slave bearings in them. We have the 3500 with the external cylinder. For now!
Also, you could get a replacement cylinder and still use the pedals, you just have to make sure you put it in right and use the right rod.
Old 04-25-2011, 08:36 AM   #12
52 Rat
52 Rat's Avatar
I decided to go with a Wilwood pedal/master cylinder set up. The throttle pedal is from a late model S10.
Old 04-25-2011, 04:05 PM   #13
mr48chev
mr48chev's Avatar
You are going to have to reinforce the firewall in that area with at least a steel plate behind it or you will soon crack the firewall out.
I can understand a guy having to put the master cylinder up on the firewall when you swap frames to the S-10 frame but i never liked to see them there as it clutters up the engine compartment too much. Someone needs to come up with bolt on under the floor pedal linkage and master cylinder (s) for the S-10 swaps.
That Wilwood setup is about as clean as you are going to get hanging on the firewall though, in and out.
Old 04-25-2011, 04:19 PM   #14
52 Rat
52 Rat's Avatar
I know, this is the initial set up. The pedal assemblies are made with mounting provision. You can see this in the photos, not where they mount through the firewall. I am in the process of fabing up a mount that ties both pedal assemblies together mounting to the firewall and dash support.
Old 04-25-2011, 04:41 PM   #15
mr48chev
mr48chev's Avatar
Good enough, I have seen enough over the past 40 years that didn't have any sort of reinforcement to want to ask.
