Old 03-22-2003, 02:12 PM   #1
reefermadness
Question I-6 Headers
Hi all,
My ehxaust manifold recently took a sh*t, and I am thinking of running headers (or would that be a header?) on my 72 in-line 6(250 CU). I was wondering what this job entails, and if it is worth it. I would appreciate any input, as I am pretty ignorant on this subject. Thanks
reefermadness is offline   Reply With Quote
Old 03-22-2003, 02:25 PM   #2
lpaine
lpaine's Avatar
I think there was/is a company called clifford research they are 6-cylinder specialists. Should have a web site.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 03-22-2003, 02:32 PM   #3
dubie
dubie's Avatar
check out www.stoveboltengineco.com
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-22-2003, 02:34 PM   #4
reefermadness
thanks, I'm checkin 'em both out now
Old 03-22-2003, 09:15 PM   #5
Canada20
Clifford has headers and I think Hooker used to make some. They pop up on e-bay from time to time
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 03-22-2003, 10:10 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
One problem with headers ont the inline is you lose your manifold heat. Don't know how cold it gets where you are, but here in Kansas those that run headers usually go with water heat on the manifold. Not as fast as exhaust heat, but better than nothing.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-22-2003, 10:13 PM   #7
Kas68c10
Kas68c10's Avatar
I have Heddmans on mine, easy install, no leak problems. Will probably go with Clifford next time. To use their intake and water heat plate. Definately need a heat plate, makes a big difference.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 03-22-2003, 10:37 PM   #8
67sss
67sss's Avatar
How about just replacing the exhaust manifold? I sold a 6cyl to a guy a while back and he was going to use it in a boat so he wouldn't need the exhaust manifold, do you want me to ask if he wants to part with it?
67sss is offline   Reply With Quote
Old 03-22-2003, 11:12 PM   #9
reefermadness
Thanks to everyone for the help, I found a manifold that I think might work. I have to drill out a broken stud and helicoil it, but it's alot cheaper than headers. Now that you guys have given me some info on the subject, I think that I will save up for the headers. I live in southern Arizona,so I don't think heat will be a problem. Again, thanks for the input. This site is great!
Old 03-23-2003, 04:55 AM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
HI, I'm in Tucson. I have Clifford headers on my '68 stepside. Put them on in '78.
They have outlasted the L-6 292 they were bolted to and after I get them metal/ceramic coated, I'll put them back on to the next 292.
Old 03-23-2003, 09:13 AM   #11
MOTHERTRUCKERS
We have Hedmans for under 150.00.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 03-23-2003, 01:55 PM   #12
Brad
Out of the carpool lane.
Brad's Avatar
I'm putting in the Stovebolt shorty headers along with 2" pipe and Flowtech mufflers within the next 2 weeks. Let me know if anyone is interested in the results...
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
