Old 03-29-2011, 04:20 PM   #1
72tutone
Throttle sticking
When I start up my truck its runs really high RPM and then a quick hit of the pedal brings it down to normal idle RPM. I dont have an RPM gauge. Is this the pedal or the linkage near the carb?
Thanks for the help
72tutone is offline   Reply With Quote
Old 03-29-2011, 04:42 PM   #2
geezer#99
geezer#99's Avatar
Re: Throttle sticking
Might be the choke on your carb too!! What carb? What choke?
geezer#99 is online now   Reply With Quote
Old 03-29-2011, 04:51 PM   #3
tqlspec
tqlspec's Avatar
When the engine is started cold, this is normal. The carburetor has fast idle mechanism that puts it in a fast idle condition when you first start the engine (when you depress the pedal to the floor). Once the engine started and you depress the gas pedal it releases the fast idle cam, and brings the rpm down to normal idle.
Retired Navy
1972 C10 Cheyenne fleetside
350 sbc, 700r4, 3.42 rear
tqlspec is offline   Reply With Quote
Old 03-29-2011, 04:57 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
its supposed to do this
Old 03-29-2011, 06:21 PM   #5
bucketObolts
bucketObolts's Avatar
^^^ Yup, mine always has. It builds up quick air pressure from my compressor so I dont mind it.
bucketObolts is offline   Reply With Quote
Old 03-29-2011, 09:50 PM   #6
treveiger
treveiger's Avatar
mine does it too when its colder or has sit for a while.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-30-2011, 04:30 PM   #7
Wrenchbender Ret
Like the guys say, this is normal but if it is too fast to suite you it is adjustable. On a q-jet carb the adj. is on the pass side way down low on the caeb. You have to shut the engine off & open the throttle to get to it. The screw will face forward. It doesnt take much. Back the screw out a little & try it.
Wrenchbender Ret is offline   Reply With Quote
