Old 03-29-2011, 07:00 PM   #1
Joesjunk
Joesjunk's Avatar
Help! Remove a broken dip stick tube!
And ideas how to remove a broken dip stick tube on a small block.? This sucker is in there good, and it is broken off at the block!!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 03-29-2011, 07:03 PM   #2
todd99
Re: Help! Remove a broken dip stick tube!
There may be an easier way, but you could remove the oil pan and push it out.
1971 C20 Longhorn Custom Camper
todd99 is offline   Reply With Quote
Old 03-29-2011, 07:09 PM   #3
Shane
Shane's Avatar
it might take some finesse, but an ez-out will work ...
Shane is offline   Reply With Quote
Old 03-29-2011, 07:22 PM   #4
Joesjunk
Joesjunk's Avatar
ill try the easy out. thanks
Old 03-29-2011, 07:33 PM   #5
cdowns
cdowns's Avatar
you can try a piece of coat hanger and make a small j on the bottom
Old 03-29-2011, 07:46 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Don't know if it will work on the thin metal of an oil tube but we used a long coarse thread screw that fit tight in the hole and then put it through a socket with a washer on top. As you screwed the bolt in it pulled the broken piece of tubing out. This was on a small tractor engine.
Might even work on the oil tube if you had the proper tap and die or a self tapping bolt that was slightly larger than the hole.
68gmsee is offline   Reply With Quote
Old 03-29-2011, 08:01 PM   #7
JimKshortstep4x4
I have pulled several out using the right size lag screw. The lag screw is turned into the tube and then using a pinch bar with the split end on it, pry it out. If you can get on the screw a claw hammer works also.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-29-2011, 08:05 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Jim
Same principal we used but a socket and washer worked really good for pulling it out. It may be hard to get a hammer in there.
Old 03-29-2011, 08:49 PM   #9
tcb-1
Nothing to see here.....
tcb-1's Avatar
are you getting an engine ready to sell at the swapmeet in a few weeks, Joe??
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-29-2011, 09:40 PM   #10
Joesjunk
Joesjunk's Avatar
I got it, used an easy out! Thanks guys
Old 03-29-2011, 09:40 PM   #11
Joesjunk
Joesjunk's Avatar
No, im working on a 62 Impala. Want to buy it????
Old 03-29-2011, 10:35 PM   #12
tcb-1
tcb-1's Avatar
'62 humm?? let me get the Caddy done and sold.......
see you at the Shriner's swap meet in a few weeks?
Doug
Old 03-29-2011, 11:42 PM   #13
tranz am
tranz am's Avatar
glad you got it out
thats a pita for sure.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-30-2011, 02:31 PM   #14
70s chevy
70s chevy's Avatar
i had that happen to me too..i took a lag screw that would just fit and a washer then wraped some wire around the screw under washer . then screwed it in the dip stick tube..then wraped wire around my slide hammer and it came right out.. worked good..
70s chevy is offline   Reply With Quote
