Old 03-22-2003, 03:14 PM   #1
MJN
MJN's Avatar
engine backfiring
This began Tuesday night when the fuel pump died on the way home and ended up changing it in a parking lot, but now the motor will backfire when going up hill or accelerating when down shifted. The timing is right on, carb is set, new fuel filter, complete tune up two weeks ago. Also feels sluggish when under load but only backfires when it is kicked down into second gear. Any ideas? Thanks
Old 03-22-2003, 03:19 PM   #2
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
What kind of setup you running as far as carb./engine? It could be that the new pump is putting out too high pressure for your carb I dont know. Cut the Edelbrock carbs can only take like 6psi I think. Double check you timing as well because the exact same thing happened to me and it was because my distributer clamp broke so the distributor would torque itself around when I accelerated hard and under load.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 03-22-2003, 04:01 PM   #3
mtdave2
newly minted old timer
mtdave2's Avatar
are you sure you dont have a miss? or a miswired sparkplug wire?
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 03-22-2003, 08:06 PM   #4
MJN
MJN's Avatar
It is a 350 with a mild cam and a rebuilt Quadrajet. I had it running beautifully before the fuel pump went out and now it just isn't the same. I've been through everything in the ignition and it all is new. Thanks
Old 03-22-2003, 11:48 PM   #5
MJN
MJN's Avatar
heres an update, now the backfire went away, but it still feels sluggish and underpowered when giving it moderate to heavy throttle. Will try carb adjustment again but could there be something connected to the fuel pump that I'm missing?
Old 03-23-2003, 12:13 AM   #6
cdowns
cdowns's Avatar
try cleaning the fuel filter in the carb or take of the fuel supply line to the pump and blow about 10lbs of pressure back thru the tank [with the gas cap off]
Old 03-23-2003, 12:17 AM   #7
Hooter
My other Love
Hooter's Avatar
could you be having a problem with the vacum advance?, did you change brands or octane's of gasoline?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 03-23-2003, 11:09 AM   #8
MJN
MJN's Avatar
as far as I know the advance is working fine, I haven't had a chance to get gas yet, but I'll get some today and see what happens. What would blowing pressure back into the tank do? I've done that on diesels but not on gas stuff before.
Old 03-23-2003, 11:39 AM   #9
cdowns
cdowns's Avatar
theres a screen on the fuel pick up tube that some times gets gooked up
Old 03-23-2003, 11:48 AM   #10
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
try changing fuel pumps again, with another new one. The last time I bought a new fuel pump for my truck I had the same problem.......not the backfire, but the miss and power loss were there. I was not happy with my new purchase. I pulled a used on off a junk car so I could use the truck and that used fuel pump is still running my truck.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-23-2003, 12:14 PM   #11
A.P.
Black 72 Chevy
A.P.'s Avatar
Your problem started after you replaced the fuel pump. Replace it again. Some times new parts don't work.
A.P. is offline   Reply With Quote
Old 03-23-2003, 03:41 PM   #12
MJN
MJN's Avatar
The fuel pump is actually a used one off my pickup that I threw on my Blazer but since the pump only has about 1000 miles on it and the truck ran fine I thought it should work. Depending on how it runs during the week I might change the pump again. Thanks
Old 03-24-2003, 03:05 PM   #13
MJN
MJN's Avatar
well on the way to school this morning, I was accelrating after turning onto the road and it backfired, then lost all power. Then after that I floored it and it sounded like it flooded out, started popping, coughing and stumbling until I let off to about idle. I might try another carb but if it was running fine last week, what else could it be?
Old 03-24-2003, 05:49 PM   #14
Blue68
Blue68's Avatar
I'd try a new fuel pump. Since it's the only thing you changed. Also, do the Quadrajets have a sintered bronze filter or are you running a filter after the pump before the carb? May be your pumpu puked into your fuel line. You may want to test your pump out by killing your ignition system (remove the coile wire) and turning the engine over to pump some gas into a jar to see if you are getting a good squirt.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 03-24-2003, 09:51 PM   #15
Don Smith
If you are running an HEI, sometimes the wire to the pickup inside the dist. will have a cracked/worn spot on insulation and it will short to dist. body and will cause backfire and loss of power when vacuum advance mechanism moves .
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 03-25-2003, 12:02 AM   #16
MJN
MJN's Avatar
My dad says it sounds like it isn't advancing, which could be possible since I was messing with the module and had to take off the rotor, I might have popped a spring off under that and that might be the whole problem. I'll have to check it out closer when I have some daylight to mess with that thing. Thanks
Old 03-30-2003, 12:15 PM   #17
MJN
MJN's Avatar
Yep, wasn't advancing the spark. The weights under the rotor got messed up from the night I put the rotor back on in the dark. Glad that was all. Runs great now. Thanks
Old 03-30-2003, 12:24 PM   #18
krue
Designated A-hole!
krue's Avatar
Glad to hear it was something simple (and cheap) to fix.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
