Old 03-30-2011, 10:16 AM   #1
Jparks
Jparks's Avatar
Air Tank Mounting
Can I get some pics of where you guys are mouting your air tanks with a Porterbuilt Trailing Arm suspension? I have the one from RideTech but it's a tad to big for where I want to put it. I'd also appreciate some info(what brand and where you got them) on some smaller diameter tanks, that might make my original location work again. I believe the one I have now is like 7" diameter without the feet. I'd probably need a 5" diameter without the feet or figure out a different location. Thanks for the help in advance.
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 03-30-2011, 12:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Air Tank Mounting
I assume you want it under the bed?
Keith
Convert to disc brakes.
Old 03-30-2011, 12:34 PM   #3
Jparks
Jparks's Avatar
I was going to attempt to put it on the frame rails under the cab. My current tank hits the supports making it hang below the frame. I'm raising my bed floor so under that is always an option just wanted to do it the other way if possible. If not, under the bed floor they go.
Old 03-31-2011, 01:14 AM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
I just about finished putting a tank compressor and valve on the driver's side. I plan on doing the same on the passenger side. I did not put it under the bed because of I have a step side bed, which limits the room under it. I put them under the cab.
Hope it helps.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-31-2011, 01:20 PM   #5
6772owner
Gearhead
6772owner's Avatar
Well, here's mine if you have fleetside, I like it so far... I have since moved the compressor further forward to accomodate my hidden hitch and bumper brackets.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-31-2011, 02:40 PM   #6
Jparks
Jparks's Avatar
Thanks guys, I'm thinking now I maybe move them back on the side of my gas tank if I can't find any smaller diameter tanks
