Old 03-30-2011, 06:56 PM   #1
FL71C10
New steering box tips
I am installing a new steering box in my truck. Any tips for a smooth installation? 71 1/2 ton power steering, new box from Advance Discount Auto.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-30-2011, 07:03 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: New steering box tips
Put one bolt in backwards to give you a helping hand while installing. Use that bolt to line the box up on the frame and help hold the box in place while you start the other 3. Once you have the other three started take that bolt out and install it the correct way.
OhOneWS6 is offline   Reply With Quote
Old 03-30-2011, 07:57 PM   #3
FL71C10
Good idea, thanks. What about lining the new box up? Should I assume it is already in the center position?
Old 03-30-2011, 08:47 PM   #4
FL71C10
no more tips? Anyone done this?
Old 03-30-2011, 08:55 PM   #5
leddzepp
Moderator
leddzepp's Avatar
i just did this last week. mine was already centered. you will love it! no more slop in your steering.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-30-2011, 09:32 PM   #6
FL71C10
So just unbolt the pitman arm and the rag joint, and put them on the new box?
Old 03-30-2011, 09:35 PM   #7
leddzepp
Moderator
leddzepp's Avatar
yes, you will need a puller to remove the pitman arm. you can buy them at harbor freight for less than $10 or use the loan a tool prograqm at autozone or oreillys.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-31-2011, 06:27 AM   #8
FL71C10
Did you paint yours before you put it in?
Old 03-31-2011, 03:51 PM   #9
OhOneWS6
OhOneWS6's Avatar
I did not paint mine but it would be a good time to if you so desired. It's really not that hard of a job. It's not surprising there are not many tips.
