drag it like you stole it
hood release spring?
is there a such thing for these trucks? my hood is in desperate need of one. but the trucks i have seen dont have one.
negative camber //LA\\ |
Not from the factory. you could get a spring from a 73 -87 truck and make it fit Should be pretty easy conidering the work you have done so far !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
i just seems like there should be since there are two bolt holes on both sides of the hood pin catch
Resident Young Old Dude !
I have wondered the same thing, I have to take a screwdriver to get mine opened, Real bummer.. I'll have to try the 73 up idea.
Ron |
mine pops up when i pull the latch.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
There is a piece that bolts in thoes holes your talking about it bolts to the bottom of the rad support (or cradel ) and to 2 spots on the grill. The hole in the grill has a nut on the bottom the next hole in closer to the firewall it does not have a nut at the bottom that nut is on the grill support If you need more help send me a pm. Mario
Here you go have a look at the piece behing the grill. you need it to keep the grill stabel. the grill will get tougher too.
Now the others dig........
![]() Join Date: May 2002
I have one of thoe if anyone needs it, very clean $20 to your door, O.B.O
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
that large hood pin in the hood needs adjusted up or down to get the hood to pop up when you pull the latch. you shouldn't need a spring to pop it up,its built into the latch assembly.
69 chevy short wide box project 70 GMC jimmy project |
I had the same question.
Good tip Johns. KW
71 Custom 10, LWB RED, RED, RED |
