Old 03-30-2011, 11:32 PM   #1
cr34t3d_by_d4rkd3n
Need Help: courtesy light/dome light (yes i searched)
first post, wootL and hello yall...... im working on a 75 1/2t c10 short box step.
I am trying to add additional lights, their draw will be too much for the stock wiring, my question is this, the orange wire supplied to the foot lamp is receiving power from what source? Those who say orange wire off headlight switch is wrong, I cut it and lost power to running lights only...ONLY (yes search function I know)
I need to know where the factory under foot lamps get their power, I understand the whole negative switched theory, no problems there, all white leads have been discovered, removed and replaced. BUT WHERE DOES THIS ORANGE Bas74rd GO!?
Again, the orange + lead that connects to the bottom of the foot lamp is not switched, i have followed it until it hides in loom, about mid dash, held by metal tabs.
Thank you!!!!...
attached pics are INCORRECT!!
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 03-31-2011, 12:25 AM   #2
463
463's Avatar
Re: Need Help: courtesy light/dome light (yes i searched)
the orange wire is 12volt +to the dome and foot well as well as the switched cargo lamp. turning your head lamp dimmer to the left grounds and turns the int lamps on, as does the door jam switches and the wire in the truck is ok to add on 2 foot well lamps. if you test the orange wire it should be 12v or the ctsy fuse is burnt. i think the lighter is also on the same cir. i also have the same upgrade installed in my 72
Trueman
463 is offline   Reply With Quote
Old 03-31-2011, 06:39 PM   #3
cr34t3d_by_d4rkd3n
Orange wire is hot, yes, Ive established that. where does the orange come from? it does not come from fuse box, (well it does to the over head lamp, <i>not foot lamp</i>)
I know how it grounds to complete the circuit. Cigarette is not on the same circuit, it wasn't factory and is definitely not now (I re-wired)
adding an additional light on this existing circuit is NOT OKAY. an average dual element bulb can use 2.2a, stock uses 1.2a on 18g doubled wire. So again, factory wiring with 2 lamps WILL cause a fire, especially with all the old insulation around the factory routing.........
SO AGAIN WHERE DOES THE COURTESY LIGHTS GET THEIR POWER...POWER AS IN 12V + FROM???
chevy reinvented the wheel as of 73, so a 72 will be of no help to me..... WHERES ALL THE OLD TIMERS!? I NEED HELP
Old 04-01-2011, 12:03 AM   #4
463
463's Avatar
http://www.73-87chevytrucks.com/tech...instrument.jpg (18 OR -140) is feeding in to the top of the fuse block in this link and i think it's the ctsy fuse from this form http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Trueman
Old 04-01-2011, 12:37 AM   #5
cr34t3d_by_d4rkd3n
your the man!!!!! Ill start testing tommoro at light. Thank you sir!
