Old 03-31-2011, 01:01 AM   #1
Btc10
GM Radio tilting
I put my original GM radio in my 1970 c 10 and for some reason the radio is tilted down and I cannot find a bracket or anything. Can somebody help me straighten up my radio so it doesn't tilt?
Btc10 is offline   Reply With Quote
Old 03-31-2011, 01:45 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: GM Radio tilting
When I still had the factory radio in my truck I can remember there being a bracket that it bolted to at the very back. I don't have a picture of it, but I remember it being a skank to take it out.
Just did a quick search and found this thread. Someone may have taken the bracket out of your truck. There is a pic of the bracket at the bottom of the thread that will give you an idea of what you will need. I'd check the parts board and see what you can find. Hope this helps.
http://www.67-72chevytrucks.com/vboa...ad.php?t=38404
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-31-2011, 02:00 AM   #3
stich626
at the base of the windsheild there is a bracket that holds a nut clip and then a bracket that mounts from that to the back of the radio..
a piece of pipe hanger (home depot pluming ) will work..
it'll be a strip about an inch wide and 6" long or in a roll with holes in it every 1/2 "
most aftermarket radios come with a bracket thats just like that..
warning it's a royal bi pain to get your hands back there..
I mounted mine to the radio then to the firewall bracket..
good luck..
stich626 is offline   Reply With Quote
Old 03-31-2011, 09:42 AM   #4
68gmsee
Active Member
68gmsee's Avatar
This is the bracket mounting tab on the back of radio. Should be able to make one if your's has been removed. However, if I remember correctly, mine help up fairly well without the bracket with the proper mounting pieces in the front knobs. I still went ahead and installed a bracket.
68gmsee is offline   Reply With Quote
Old 03-31-2011, 10:17 AM   #5
dos0711
dos0711's Avatar
Looks easy enough to fabricate one from aluminum angle stock
dos0711 is offline   Reply With Quote
Old 03-31-2011, 11:51 AM   #6
cdowns
cdowns's Avatar
that rear strap is also a good grround for the radio
Old 03-31-2011, 11:54 AM   #7
dos0711
dos0711's Avatar
If someone could sketch it out on paper with measurements that would be awesome!
Old 03-31-2011, 12:01 PM   #8
Tink
Tink's Avatar
I just took the old radio out of our 69, if the bracket is still there I can get some measurements and what-not.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 04-06-2011, 09:30 AM   #9
dos0711
dos0711's Avatar
Would someone mind doing this? It would be appreciated...
Old 04-06-2011, 09:24 PM   #10
19seventeeCustom
Mine has been without a rear brace for close to a year with no tilting issues.
I'll check and see if I still have the bracket that was attached to the radio when I received it. I know I still have the speaker and original harness.
Mine original AM is only used as a dummy for the hidden system.
19seventeeCustom is offline   Reply With Quote
Old 04-06-2011, 10:02 PM   #11
Willys47
Willys47's Avatar
HERE IS SOME PIC I SAVED OFF THE NET crap my caps lock was on sorry for being so loud
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 04-06-2011, 11:12 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Man, those fingers look familiar...... The larger piece with the two holes fastens to the inside of the firewall. If the holes aren't there there should be a couple of indented places where the holes need to be drilled. Don't forget these screws will go all the way through the firewall and show on the outside...
LockDoc
Leon
