Old 03-31-2011, 11:41 AM   #1
cb1965
cb1965's Avatar
Engine temp??
Hey guys my truck runs at about 210 degrees. Is that a normsl temp or is it too hot. For a while i ran it with no tstat and it was steady at about 180f. I had heard that running it with no tstat would cause sludge to build up. So i put a 180 tstat and now runs at 210f. Im not too comfterable with it at that temp. Any ideas or suggestions? 350/ powerglide combo
Thanks.
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 03-31-2011, 12:02 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Engine temp??
Yes, you need some kind of restriction in the cooling system. I would try a 190 stat, and see if it cools down. I know it sounds backwards, but that is the way it works. If you still have issues, try summit or jegs and see if you can find a restrictor disc. I had a jeep with a 304 that would not run cool with a stat. The disc made it run at 220 constantly. BTW, I dont consider 210 hot if it stays there.
Dunenutt is offline   Reply With Quote
Old 03-31-2011, 12:12 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: Engine temp??
I would say it's a little high but not bad. Have you checked other stuff like fan shroud, clutch, radiator leaks, and so forth?? Also is that at idle or when you're driving?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-31-2011, 12:26 PM   #4
glos55
glos55's Avatar
Re: Engine temp??
210 seems high to me, it should be running around 180-190 maybe 200 on a hot day in stop and go traffic. The restriction in the cooling system keeps the hot coolant in the radiator longer so it can be cooled by the fresh air coming through it.
glos55 is offline   Reply With Quote
Old 03-31-2011, 12:26 PM   #5
erock805
erock805's Avatar
Re: Engine temp??
yeah go with a 190 or 195, and run a overflow tank, look at a shrowd and check out your fan.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 03-31-2011, 12:41 PM   #6
McC_65_91
McC_65_91's Avatar
Re: Engine temp??
I got a 350 outta a 72 camaro, original 4speed. had a 185 thermostat in it and ran at 210 also, i thought this was high and switched to 165 to try an lower it and it made little to no difference... I dontn worry about it, dont think its too high
McC_65_91 is offline   Reply With Quote
Old 03-31-2011, 04:41 PM   #7
cb1965
cb1965's Avatar
Re: Engine temp??
some say its too high some say its good???? does it depend on region?
temp drops a bit while driving but maintains prety close to 210 most of the
time.fan shroud is good and fan is a 4 blade original style with no clutch.
maybe i should change tstat to a 190 o 195 and get a flex fan. what do u think????
thanks for replies
'66 chevy lwb c10
'65 chevy lwb c20
Old 03-31-2011, 05:27 PM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Engine temp??
180 Degree Thermostat is what you need.
Is the Thermostat froze?
210 Degrees is to hard on the motor and it will run hot.
Probably running rough with it being that hot.
If thermostat is ok check the water pump to see if it is flowing good.
Check for water leaks too. Fan cooling properly?
Engine & Drivetrain
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 03-31-2011 at 10:08 PM. Reason: http://67-72chevytrucks.com/vboard/forumdisplay.php?f=24
1Bad62Pro/Street is offline   Reply With Quote
Old 03-31-2011, 05:30 PM   #9
scum1
scum1's Avatar
Re: Engine temp??
i got steered away from flex fans on here so im sure you will here the same, i would agree on a 190 tstat. mine runs about 190-195 and im missing part of the radiator shroud
scum1 is offline   Reply With Quote
Old 03-31-2011, 08:13 PM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Engine temp??
Make sure you have a good rad cap. Also, make sure the lower hose still has the spring in it so it wont get sucked flat. That will cause a flow restriction.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-31-2011, 08:30 PM   #11
lakeroadster
Re: Engine temp??
Where is the temperature sensor located at on the engine? It makes a big difference in the fluctuations of the reading you get.
On my '65 C10 (350 CBC) it is in the drivers side head. The temperature rises to about 210 before the thermostat opens, then the temp drops to about 180 - 190. (Running a standard GM type fan)
On my Model A (also running a 350 SBC) it has a mechanical gauge screwed into the water pump, and an electronic gauge in the drivers side head. The mechanical gauge in the water pump never reads over 180 (with a 180 thermostat) the one in the head does just like my C10... up to 210, then down to 180 - 190 when the thermostat opens. (Running electric fan)
lakeroadster is offline   Reply With Quote
Old 03-31-2011, 09:06 PM   #12
cb1965
cb1965's Avatar
Re: Engine temp??
Cap is good n lowe hose has spring. The temp sensor is on tstat housing and there is no leaks
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-01-2011, 10:14 PM   #13
cb1965
cb1965's Avatar
Re: Engine temp??
and the winner is.......... tstat!!! so far. so i went to remove the tstat
and come to figure it is a 195F and not a 180F like i wanted when i first
purchased it (should of checked). so i swaped in a 180F and the temp has
maintained at 180-195 range witch im way more comfterable with than the
210F that it used to run. So i guess i will call this one problem SOLVED
thank you all for the input
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-01-2011, 11:24 PM   #14
protrash64
protrash64's Avatar
Re: Engine temp??
Cool to hear you figured it out!!
Old 04-02-2011, 01:18 PM   #15
Psycho71
Psycho71's Avatar
Re: Engine temp??
Glad it was an easy fix.
My advice was gonna be to pull the t-stat and put it in a pan of water on the stove. heat it til it opened and use a candy thermometer to check the temp at which it opened.
But it sounds like you have it going on now.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 04-02-2011, 02:50 PM   #16
cb1965
cb1965's Avatar
Re: Engine temp??
yeah to day i drove it around for 20-25 min and let it idle for another 5 min and temp maintained at 180-195 range.
'66 chevy lwb c10
'65 chevy lwb c20
Old 04-02-2011, 09:19 PM   #17
clinebarger
Re: Engine temp??
There was nothing wrong with 210 degrees, Water gets into engines from condensation, The only way to get it out is boil it out, Water boils at 212 degrees (at sea level). The engine & oil will last longer running at 210 degrees.
clinebarger is offline   Reply With Quote
Old 04-02-2011, 10:16 PM   #18
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Engine temp??
my one thing that none of you hit on what size or what hot Plugs are you running 43 R are ok 44 R Ac Delco You might be running to much timing 8 is where you really want it put a timing light on it check your plugs if your going lean you will burn that motor down in a heart beat.Remember if you have checked your tstate and you have a fan clutch and and shroud and your still hot check what i told you to check or buy your self a heat gun and point it at the radiator my be your gauge is off
stsalvage is offline   Reply With Quote
Old 04-03-2011, 01:42 AM   #19
AustinScott
AustinScott's Avatar
Re: Engine temp??
Just to add to this a bit.. Timing is different for every engine build, unless they are built exactly the same... so one mans ideal golden timing number might not translate to another.
I would do the ping test and back off from there, it truly is the best and simplest way to get your engine running @ its peak....
NOTE!: you will need a very good ear, if you don't think you would know what to listen for during the "ping test", then 8-10 timing " no advance" is safest.
But, if you feel you can tune it, start at 8 "no advance" & move up until you hear the ping "rocks in a coffee can sound under full throttle" and back it down 1 or 2 deg.
This way you will know your timing is set, and you can move onto other trouble shooting methods for high temps in a SBC...
AustinScott is offline   Reply With Quote
